Good morning. Has anyone used 3m Super 77 spray glue for the rubber sill covers on a roadster? I washed and roughed up both sides to glue down. I used weldwood contact cement for one side, but then ran out. I have a can of the super 77 spray on the shelf so was wondering if that is strong enough.
Thanks
Glueing down sill cover
Posted by Soling2003
Pahoa, HI, USA
![]() 1969 MG MGB MkII
Feb 9, 2019 11:26 AM
Joined 5 years ago
Cornfgl
Graham Cornford
Bellville, TX, USA
![]() 1974 MG MGB GT V8 "Goose Poop"
Feb 9, 2019 12:11 PM
![]() Joined 6 years ago
Gary,
AFAIK, any of the 3M contact adhesives will be suitable, as long as the one you use does not say not suitable for rubber.
Just go by the instructions, and be careful of overspray.
I used their products when glueing an insulation material, and very pleased with the way it went.
Cmpozr
Ray Weidner
Forest, VA, USA
Feb 9, 2019 03:06 PM
Joined 3 years ago
I'm not a fan of Weldwood contact cement. I used it on covering a hardtop with vinyl, but the heat from the sun softens it, causing bubbles. I've got to find a heat-resistant, brushable product.
74 Chrome Bumper MGB
71 Triumph TR-6 (original owner)
"Every LBC is a rolling restoration."
"These are the cars that try men's souls."
"The past is a nice place to visit, but I wouldn't want to live there."
Pahoa, HI, USA
Feb 9, 2019 03:26 PM
Joined 5 years ago
Thanks Graham. I think I will try it.
Ray, I’ve used Weldwood contact cement for lots of stuff and never had a problem. But not sure I ever used it on something that sat in the sun heating up, especially black. It stuck great in 80 deg. Weather and in the shade. Will see what happens long term.
Feb 9, 2019 03:37 PM
![]() Joined 12 years ago
The 77 3M spray adhesive is not up to the task in my experience. Buy a can of real contact cement and scuff the back of the rubber cause the mold release used is adhesive resistant.
Pete
Pete
Pahoa, HI, USA
Feb 9, 2019 03:45 PM
Joined 5 years ago
Pete. I did clean and scuff both the back of the sill cover to get rid of mold release and any contaminates and the sill on the car to make sure that there is good contact.
The only thing I was wondering was if the 77 spray adhesive was up to the task. I have my doubts, but have never tried it on anything heavy like this before.
I tried glueing down some really good and expensive engine compartment sound deadening stuff I had left over from a boat job I did years ago, I am a bit Leary trying something I’m not sure about. The sound deadening stuff was heavy vinyl on one side, high density foam almost like lead in the middle, then a low density foam on the inside for dead air space. That foam looked ok, but after it was glued down and I checked to see how well it stuck, it was a hell of a mess! The foam was too old and fell apart. When removing it it left a bunch of the old foam on the trans. Tunnel and I had to take a wire wheel on the drill to get it smooth enough go over it. I had kept this stuff around for years just for this purpose. The 3/4” similar stuff for the firewall I didn’t even try.
Feb 9, 2019 06:47 PM
3M makes a "90" version of the spray adhesive. order of magnitude better than the 77. I still think the good old Gorilla Snot in a can is the best. Weatherstrip adhesive is also very good, but I only see it sold in squeeze tubes and you would need about 3 per side.
Pete
Pete
Fairfield, CA, USA
![]() 1973 MG MGB MkIII
Feb 9, 2019 08:50 PM
Joined 13 years ago
I've not had much success with 3M spray adhesive. But brush on contact cement has worked for me.
If you've got the spray, try it. It it works, it was the right stuff. If not, it wasn't<G>
SUs, Datsun 5-speed
SUs, Datsun 5-speed
Pahoa, HI, USA
Feb 9, 2019 09:18 PM
Joined 5 years ago
So broke down and bought some more contact
Cement in a can since I was out. Just to make sure it holds well
DrewM
Drew Maddock
74 MGB roadster, Southern California, USA
Feb 10, 2019 11:40 PM
![]() Joined 13 years ago
You know this, but be sure you don't apply the glue and then slap things together right away. The glue needs to "set up" which means leaving it alone for at least a minute or two before you put the sill cover on. And you need glue on both surfaces since apparently it's the glue sticking to the other glue that holds things together. I guess. Also things need to be warmish so I suppose gluing on a cold day may be less effective.
You might experiment a little by gluing just a section of the sill cover, then leaving it for a day or two. If you can't pull it off easily, the glue works and you can go ahead and do the rest. If it peels off, go to Plan B without creating a huge mess to clean up. I wonder what the factory used? I bet it was brush on glue of some sort instead of spray glue which would have been pretty toxic to be using all the time. But that's only a guess. Speaking of toxic, avoid inhaling the fumes if you possibly can.
I've had good luck with 3M spray glues, but the spray gets everywhere and makes a mess unless you thoroughly mask everything nearby, including the floor. I'd much rather use a brush-on glue, myself.
Pahoa, HI, USA
Feb 10, 2019 11:53 PM
Joined 5 years ago
Thanks Drew. I got the second one done today. Picked up a small can of contact cement and put it on. Yes, it has to wait 15 minutes. I did let it sit in the sun for a few minutes to warm up, (it is 80 here) both when I cut to trim and put the hole in for the seatbelt, and again after the glue was on before fitting. It actually goes on fairly easily all at once.
Next is the rear cockpit surround and the new speaker box for the back. Finally things are starting to come together for the interior.
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
