Expansion Tank
pcgold Avatar
pcgold Paul _
SK, Canada   CAN
74B.
I want to put in a coolant overflow /Expansion tank.
I’ve searched and scoured this forum for pics of a Chrome tank. I’ve seen it in the past but can’t find it now.
Who here has done this with a Chrome/ stainless steel tank? Pics?
Just ask evilbay - there's hundreds listed.
tvrgeek Scott S
Be clear what you are looking for . There are three solutions often confused:
#1 Overflow bottle. Tank with a hose to the top to just take overflow, but allows air to replace any lost fluid. Useful when the radiator tanks are of sufficient size and higher than the engine.
#2 Recovery bottle ( what I run) Bottle hooked to above the rad cap seal like the overflow bottle, but the hose stays submerged in a resoviour of water, so the system remains full of water only as the engine cools and the water pulls a vacuum to suck fluid back, not air.
#3 Header tank. It is part of the pressurized system so the pressure cap is on the tank; radiator is sealed. It is often placed high above the engine if possible. It is usually plumbed to the low side. Some claim it helps separate air from the water but with the pressures we run, I doubt it. Sometimes they have multiple lines running from several "high points" to keep any trapped air out. I have been struggling to see why this is any better than a recovery tank. I do note most newer cars have moved to the header tank, but I believe it is because the new radiators have smaller tanks rather than any inherent efficiency.
On modern cars, many of the header tanks have a fluid level sensor to turn on a idiot light.
There is a lot of contradictory information and miss-use of the terms on product sales sites, so look carefully.
Check Jegs, Summit, Moroso or any hot-rod suppliers for bling. They like polished aluminum or stainless. I use a $2 water bottle rather than a $250 polished stainless bottle. Works for me.
pcgold Avatar
pcgold Paul _
SK, Canada   CAN
Thanx TVRGeek.
#2 is what I am looking for.
I've looked on evilbay and elsewhere. Just not sure which one to get.
ClayJ Avatar
Mt. Olive, MS, USA   USA
I use a small slender 14oz plastic bottle for a recovery tank zip-tied to the LH radiator support and hanging next to the radiator. Works great.
Late Bs used an "expansion tank", not a gravity fed header tank.
mgdriver67 Avatar
mgdriver67 Silver Member Stephen Farrell
Pensacola, FL, USA   USA
1967 MG MGB MkI "Lulu"
2017 Honda Ridgeline 4WD "Mom's Truck"
2019 Subaru Crosstrek XV "Suki"
Those sure look nicer than my opaque white plastic tank. Someday maybe I’ll upgrade. It never had one originally though.
tvrgeek Scott S
I believe the pressure cap was on the expansion tank and it was mounted high on the fender. Call it expansion or call it header, it is the same. They only had one tube to it. MG was a little more clever than Triumph as the tube was big enough for water to actually flow through it. The Stag is much smaller. I do not buy the necessity for it to be gravity fed with just a single high point connection and fed to the bottom of the tank. That should only matter when filling initially as long as it is fed and drawn from the bottom of the tank. Only fluid will flow. Cooling water pulls a vacuum sufficient to pull it a foot. Tanks with multiple fittings in the pressurized loop for through flow are a different matter. That case may fall under the "it depends".
You can also run a header tank and a catch bottle. This lets the header tank find it's own natural fill level without dumping anti-freeze on the ground. If yor header tank has th ecap right at thre top ( MG does not) you can run one with a recovery bottle so the header tank is just additional volume replacing the too small rad tanks and remains completely full.
The goal is to keep the radiator full. Take your pick. Call it what you wish. If you wanted to get fancy, a 1/8 inch tube from the highest point of the heater hose might purge that system into an expansion tank. I have not head we have any head steam traps like a small block Ford or the Stag 3.0
Gerry Avatar
Prairieville, LA, USA   USA
I used a proper rad cap and a windshield washer bottle and bracket. Looked good and worked just fine. No ugly modern square bottle to stick out like a sore thumb
TonyV Avatar
TonyV Tony V
Rutherford, NJ, USA   USA
mvheim Avatar
mvheim Silver Member Mark Heim
CA, USA   USA
1966 MG MGB "Uroboros"
I have never understood why anyone would want a metal expansion tank. You can't see the level of the coolant, so it's exactly the same as the radiator top tank -- you have to pull the cap to check (and since it is lower in the car and a deeper container, and there is no light in there, good luck).
The whole convenience factor is having a visible coolant level so you know when to top up (anticipate and prevent disaster), and having a cap you can remove with the engine warm to refill.
Max Heim
'66 MGB California Melee 2006 & 2014 (passed along to another enthusiast)
'66 MGB (just launched)
+1 Yes No Thank
  PeterC thanked mvheim for this post
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1969 MG MGB MkII
1971 MG MGB GT    & more
Good point Mark but I have had experience with the plastic ones cracking with age and the desert heat so I am going to use the late brass tank on mine. It probably could be chromed if one desired. From what I remember, it could be used as an expansion tank or overflow container depending on where the pressure cap is located? It has been covered recently on which goes where.
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
As others have said use Goggle to your advantage. Type in what you want and select images to see the varieties. Besides Ebay, you have Jegs, Summit, Speedway, etc.
I ended up using a spike expansion tank on my midget because of size
https://www.speedwaymotors.com/Spike-Chassis-005-2062-Aluminum-Expansion-Tank,6668.html
95015710_L_10b77662-1fc0-4c34-83ba-514f40ae8176.jpg    14.9 KB
jseabolt Avatar
jseabolt James Seabolt
Mount Carmel, TN, USA   USA
In reply to # 3907254 by pcgold 74B.
I just got through installing an aluminum tank and radiator in my Fiat Spider Monday. Sorry not MGB related but might give you an idea. I got it for $40 off eBay.
This tank should work on an MGB as long as it doesn't use a radiator cap on the tank like my 77 does.
1977 MGB
1980 Fiat 124 Spider (turbo)
1987 Yugo (1500 turbo)
1981 Trabant 601
1987 Citroen 2CV
1968 Ford Fairlane 500
IMG_20190311_164455405-1612x1209.jpg    46.8 KB
IMG_20190311_164432746_HDR-1612x1209.jpg    62.1 KB
ClayJ Avatar
The metal expansion tank on the late Bs is a pressure vessel, it sees the same pressure as the cooling system.
A overflow tank is not pressurized, it just catches the coolant that is ejected from the cooling system as the coolant expands due to heat. With the right setup the overflow tank can also draw coolant back into the cooling system as the system cools. My 14oz overflow tank catches and returns about 10ozs of coolant from cold to hot.
