DIY pedestal type Hi ratio rocker arms for my MGB
Gerald O Avatar
Gerald O Gerald O'Docharty
1978 MG MGB
This could just be a drop in pressure visible at the gauge due to the already restricted size of the fitting that you tapped into. As I recall, the fitting on the block that feeds the braided hose to the T fitting is already a pretty small hole.
Pressure in the main galleries may be higher. You'll need to take a pressure reading off the main gallery to be sure.
Edited 1 time(s). Last edit at 2019-03-12 02:57 PM by Gerald O.
Berwick, NS, Canada   CAN
Thanks Gerald. What would be the easiest way to take a pressure reading of the main oil gallery?
Adrian
Gerald O Avatar
1978 MG MGB
You could tap into an oil cooler line by inserting an appropriate T fitting.
Or rig up a modified oil filter with a fitting tapped into it.
in any case, if it turns out that your pressure gauge is giving a false reading due to the 'pressure divider' you've created, you'll need to think about relocating its feed point permanently.
Edited 2 time(s). Last edit at 2019-03-12 04:06 PM by Gerald O.
+1 Yes No Thank
fast-MG.com Avatar
That's the reason I source my oil from on top of the block boss that mounts the filter.
Dave Headley, dba FAB-TEK offers full service race car parts and preparation for MGB & MGA race cars, SCCA and Vintage. Dave is a mechanical engineer and has raced MGBs since 1963.
Gerald O Avatar
1978 MG MGB
Adrian, I measured the diameter of the hole drilled through the block fitting to be 0.062" (1.575 mm). This works out to a cross-section area of 1.95 mm^2. The four 0.025" holes in your spray bar total 1.27 mm^2.
1.27/1.95 = 0.65. So this means you could be seeing as much as a 65% pressure drop after the fitting and at the gauge. Though probably not quite that much, due to the boundary effect of the small 0.025 holes which will flow less than a single larger hole of the same total area.
Edited 1 time(s). Last edit at 2019-03-12 06:33 PM by Gerald O.
+1 Yes No Thank
Well... if I take the 40 psi I have and add 65% I get 66psi. Your assessment seems legit Gerald. thumbs up ...and thank you! I expect it is all fine the way it was but I can't look at the gauge reading 40 psi like that and be happy.
I have cut things up and will plumb the little fella off the oil filter housing some time tomorrow. I was short a fitting and 2 feet of high pressure hose or I would have had it done tonight.
Adrian
So I plumbed the oil feed to the rockers via the oil filter housing... and my oil pressure gauge reads as it should. Four 25 thou holes spewing hot 70psi oil is a LOT of oil. These rocker arms may fail for some reason... but it won't be due to lack of oil!
I didn't want to drill and tap the block where the filter adapter bolts to so I put my fitting on the bottom of the aluminum adapter itself. This would be a better location because you could keep an eye on the fitting easier. It looked a bit awkward to drill and tap with the engine in place so I did the adapter instead.
Super big thank you to Dave Headley for coming up with this idea and then helping me to make my own setup!
Adrian
Edited 1 time(s). Last edit at 2019-03-15 10:58 AM by pinkyponk.
+1 Yes No Thank
fast-MG.com Avatar
You are welcome!smileys with beer
+2 Yes No Thank
In reply to # 3907587 by Gerald O You could tap into an oil cooler line by inserting an appropriate T fitting.
Turns out it was a false reading as we suspected... a modified oil filter would be a cheap way to see what was what. Just no way I would be happy looking at the oil pressure gauge reading 40 pounds.
Adrian
I took the rocker cover off to have a look at how things were looking and found this. So they held up for roughly a mile and a half. * sigh *
Adrian
Edited 1 time(s). Last edit at 2019-03-13 07:46 PM by pinkyponk.
Rocker arms 011 copy.jpg    66.5 KB
fast-MG.com Avatar
Did you check your springs for coil bind? Any valve interference to block? Any sign of pushrod side loading in the head holes?
Gerald O Avatar
1978 MG MGB
Oh dear! I hope you accounted for all the bits...
Yes, I checked for coil bind. There is no contact with the valves to the block... my combustion chambers are deeper than the valve lift. The pushrods are 1/8" away from the holes. The little outer sleeves slid out with no effort. They should be a press fit over the pivot shaft.
Adrian
In reply to # 3908344 by Gerald O Oh dear! I hope you accounted for all the bits...
Not yet. I can see 3 needles sitting in the #1 tappet. I can't find my magnet on a stick to retrieve them. I didn't search too hard... I just went in and had a beer and watched tv.
Adrian
Edited 1 time(s). Last edit at 2019-03-14 06:12 AM by pinkyponk.
fast-MG.com Avatar
Yes, those are supposed to be press fit. Did you say they came from Rock Auto, not GM? I don't think that rocker has been used by GM for at least 15years. I've seen a few that loosened slightly due to large pushrod side loading from contact in the head hole. Were the bolts still tight? Are any other rockers showing signs of loosening?
