Best new seat diaphragms?
JoeReed Avatar
JoeReed Gold Member Joe Reed
Cordova, TN, USA   USA
1978 MG MGB "Kermit"
My wife has complained (for quite a while!) that the passenger's seat was uncomfortable. Being a typical husband, I pretty much ignored here since mine felt fine. smiling smiley Since the weather sucks too much now for golf or top down driving I decided to spend a little time in the garage...
Turns out that the foam is actually in excellent condition - it was replaced by the PO just prior to me obtaining the car. But...it's pretty apparent that he didn't replace the webbing. I'm sure my side looks almost as bad, but I haven't looked at it yet.
I'd prefer to use the diaphragms, but I know that there have been problems with some in the past with the hooks tearing through....although those threads I researched are a few years old. Anyone bought and installed new diaphragms recently? If so, and if they didn't present that problem, where did you source them? Moss? TRF? Other?
IMG_20190209_172017008.jpg    62.2 KB
chris Avatar
Pendleton, OR, USA   USA
Many switched to the webbing rather than trust a diaphragm. None of my purchased diaphragms had the ripping out problem so I have stuck with the Moss version (which I'm pretty sure is the same as elsewhere).
Used English car parts.
JoeReed Avatar
Yeah...I doubt there's more than one manufacturer of an item like that. I'm going to use the diaphragms.Just need to yank the other seat to see if I need anything else.
While the seats are out I suppose I'll put in the new carpet I've had since 2006 eye rolling smiley Hopefully that'll be all I do for this project (other than cleaning/repainting the seat frames).
I may also replace the seat packings. The current packings are some I made from 1x2 wood (maybe oak, I don't remember) painted black. They're still perfect, but I may get some 3/4" square steel tubing and make another set. The 3/4" height hasn't been a problem at all....and the steel tubing would outlast me....
I'm trying to avoid project creep.....don't want to end up doing a total resto grinning smiley
Edited 1 time(s). Last edit at 2019-02-09 07:10 PM by JoeReed.
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1969 MG MGB MkII
1971 MG MGB GT    & more
The diaphragms will make you sit higher so might want to check the seat height before you replace the wood strips.
Fresno, CA, USA   USA
REALLY Curious about your numbers. ???? I am 5' 6" and weigh 140 lbs. 1x2" seat rail wood packings would make me sit too high. ???? Normally the packing is about 1/4" even 3/4" would be too much. Are you more "Height Challenged" than I ?? confused smiley
In reply to # 3888768 by JoeReed My wife has complained (for quite a while!) that the passenger's seat was uncomfortable. Being a typical husband, I pretty much ignored here since mine felt fine. smiling smiley Since the weather sucks too much now for golf or top down driving I decided to spend a little time in the garage...
Sir Henry Royce
co-founder of Rolls Royce .
DrewM Avatar
DrewM Drew Maddock
Solid diaphragm
1. Stiff, hard and unforgiving
2. Uncomfortable
3. Unhappy wife
Straps
1. More flexible and forgiving
2. Much more comfortable
4. Happy wife = Happy life
I've used both -- and the straps win hands down. Even better, the new straps sold by Moss Motors are no longer the old rubber strapping. The new ones are a different, sturdier material that looks like it won't degrade like rubber but is still flexible enough to make your bottom say "Thank you, thank you very much." I redid my seats just last year using the solid rubber diaphragm.
Mistake. Hard and unpleasant. And I was sitting way too high for comfort. Out came the seats once more to have the diaphragms removed and the new Moss straps installed. Much more comfortable sitting position. Very happy now.
JoeReed Avatar
In reply to # 3888918 by oleanderjoe REALLY Curious about your numbers. ???? I am 5' 6" and weigh 140 lbs. 1x2" seat rail wood packings would make me sit too high. ???? Normally the packing is about 1/4" even 3/4" would be too much. Are you more "Height Challenged" than I ?? confused smiley
I'm 5'7" and don't find that the 3/4" packings really seem any different that the original 1/4" ones (a 1x2 is actually 3/4" thick). After all, it's only 1/2" difference....two people of different weight probably create more difference than that by compressing the seat foams....
Edited 1 time(s). Last edit at 2019-02-09 10:20 PM by JoeReed.
JoeReed Avatar
In reply to # 3888920 by DrewM Solid diaphragm
2. Uncomfortable
3. Unhappy wife
Straps
Oh, thanks a lot.....now you've got me second guessing my decision to use the diaphragms devil smiley
Fresno, CA, USA   USA
10-4 thumbs up
In reply to # 3888926 by JoeReed
Sir Henry Royce
Wray Avatar
Wray Gold Member Wray Lemke
., SC, USA   USA
Joe, Gerry made sets of packing out of aluminum for a bunch of us years ago. If looking for something long lasting you might consider using Starboard. It's virtually indestructible, comes in several thickness. Not sure where you might find a place nearby that would have small pieces for sale. I might have enough scrap to make a set of packings.
Donthuis Avatar
Donthuis Don van Riet
These webbing straps last for a VERY long time. I once compensated for the slight stretching of my 1972 originals by bending the metal hooks at the ends somewhat shorter. smiling smiley
Even with these old straps in I had some difficulty getting under my steering wheel after putting new seating foams and seat covers in. Fortunately these foams settled in a few months thumbs up
Of course the rubber diaphragms have another to some of us slightly theoretical disadvantage, especially in Tourers: they ventilate less and moisture or rain in the foams is kept inside much longer
JoeReed Avatar
In reply to # 3889017 by Wray Joe, Gerry made sets of packing out of aluminum for a bunch of us years ago. If looking for something long lasting you might consider using Starboard. It's virtually indestructible, comes in several thickness. Not sure where you might find a place nearby that would have small pieces for sale. I might have enough scrap to make a set of packings.
I'm not really concerned about longevity....the wooden ones I made 14 years ago are still perfect....and I'll be 70 next month smiling smiley I'll likely just keep using them. The thought of making new ones was just the onset of the might-as-well disease....gotta try to avoid that!
JoeReed Avatar
I'm going with Drew's advice and ordering the webbing. I trust his opinion,,,,and figure there must be a reason the factory changed. I don't think it was a cost consideration, since I can't see the webbing and it's frame (and assembly) being cheaper than the diaphragm...
chris Avatar
In reply to # 3888834 by JoeReed Yeah...I doubt there's more than one manufacturer of an item like that. I'm going to use the diaphragms.Just need to yank the other seat to see if I need anything else.
It sounds like you are well along your way to "project creep". smiling smiley
chris Avatar
I haven't heard of these new straps. Drew has me wondering also since the last set of seats are just sitting in the 65 waiting for the interior assemble.
