1974 MGB Transmission Rear Seal Removal
MerrittIsland74MGB Avatar
Merritt Island, Merritt Island, USA   USA
Last step before installing the engine is replacing a leaky rear transmission seal (22B369 MOWOG transmission). There was a metal cover over the seal that will not come out. It actually appears to be a sleeve that goes to the rear bearing in the transmission. I tried a slide hammer and that did not work. Based on some reading then moved on to a chisel/dremel. No luck. As you can see it is a mess now. BTW - the seal under the cover did eventually break and I was able to remove it. The replacement, Moss 121-120, looks pretty wimpy compared to the one I removed.
Does anyone know to remove this sleeve?
seal.jpg    37.6 KB
That's the outer sleeve of the rear seal and must come out...
The OE seal is substantially heftier than the replacement, but the replacement works fine...
Brightguy Avatar
Brightguy David Sippola
Lawrenceburg, IN, USA   USA
1976 MG MGB MkIII "TBD"
Looks like this if you get it out in one piece, sorta one piece.
IMG_3108 (1).jpg    10.1 KB
Brightguy Avatar
You might try heating the aluminum which should expand somewhat more than the steel. More than likely you're going to have to very carefully, with a not very wide, but thin chisel, try to create a gap between the remaining outer seal housing and the inner boss of the transmission seal surface. I would try to select an area of the remains of the seal that has a larger chunk protruding and try to use a hammer and said punch with an abundance of caution. Once you get a gap I would try to replace the chisel with another rounder less damaging implement.
BumbleB74 Avatar
BumbleB74 William Milholen
ouch....you got some prying and trying work left to do. The replacement will not have all that metal backing, and will go in pretty easy.
