My MGA project
Woodysrods Avatar
Westbank B.C., Canada   CAN
I think I have on too!
And will measure next time I go out to the shop!
Brian
1954 MGTF 1800
1962 MGA MKII
mgaex189 Avatar
mgaex189 Gold Member Giovanni Delicio
1955 MG MGA 1500 "C2"
1955 MG MGA 1500 "4-seater"
1955 MG MGA 1500 "C1"
Hi Thomas,
there is a vendor in Germany that sell the spring (Pos.43).
You would need also the bracket (Pos.44), but it's not available.
It's very easy to manufacture the bracket by yourself.
If you want, I may buy it for you and send the spring to OZ.
Gio
Bonnet spring.JPG    13.9 KB
Spring price.JPG    25.3 KB
mgaex189 Avatar
@ Jim Cheatham:
The spring you are using is a bit too long. The second support bracket for the rod is missing.
But it's a beautyiful carsmileys with beer
Gio
missing rod support.jpg    6.5 KB
mgaex189 Avatar
Hi Thomas,
attached a sketch for the bracket.
Gio
bracket for bonnet rod.jpg    3.5 KB
ghnl Avatar
Mebane, NC, USA   USA
1961 MG MGA "Calvin"
Here's a measurement on my MGA. I'd guess an extension spring about 6" long at rest would be about right.
Eric Russell ~ Mebane, NC
bonnet_latch spring.jpg    29.4 KB
MGB65B Avatar
MGB65B Gold Member Thomas Aczel
Sydney, Kurrajong Hts, Australia   AUS
1962 MG MGA MkII
1965 MG MGB "Dad's Little White Car"
Hi Gino and Jim
Thanks for all this information.
I've just looked carefully at my car. In typical form, the spring AND the support bracket that's mounted on the rod are both missing.
The rear bracket for the rod that mounts on the engine bay side of the wheel arch is there, and complete. The one further forward is partly there, but it's not complete. Enough is still there however to support the rod.
How is the small bracket that's mounted onto the rod that Gino has shown a drawing for fixed to the rod? I presume it would need to be more than a friction interference fit? Is it tack welded on?
As for the spring Gino, thank you so much for offering to help. I'll see how I go trying to source one locally first. I'll contact you if I have no luck.
IMG_0032 2.jpeg    47.6 KB
3066james Avatar
Amelia, VA, USA   USA
Hi Gio,
Thanks for the kind words about my car.
My car does have a second support bracket for the rod but it’s farther forward than the one shown in your picture and shaped differently. Mine is actually shaped just like the rear one. It is spot welded in place so I’m sure it’s original.
In reply to # 3861922 by mgaex189 @ Jim Cheatham:
Gio
95521B2A-B2DE-44D5-AE22-7BF6F34B5C49.jpeg    54 KB
B28A010B-CA70-460D-BF03-467C8DC57EB3.jpeg    34.2 KB
FF93E28B-BDCF-4852-86C9-B52F4C812596.jpeg    33.5 KB
ghnl Avatar
Mebane, NC, USA   USA
The bit that is on the release rod is not welded to the rod. With the spring tension applied it stays put. But with tension released you can slide it forward or backward to move it to the desired position.
MGSerge Serge V
Maaseik, Limburg, Belgium   BEL
Hi
My local Mg parts supplier has the spring and bracket for less then 25 euro
If you are interessted you can let me know
Serge
MGB65B Avatar
1962 MG MGA MkII
In reply to # 3862954 by MGSerge Hi
Serge
Thank you. PM sent.
I don't want to take up any more of Bob's thread. Thanks too for everyone else who commented to me about the bonnet release rod "anti-rattle spring" and bracket.
ghnl Avatar
Mebane, NC, USA   USA
In reply to # 3863151 by MGB65B Thanks too for everyone else who commented to me about the bonnet release rod "anti-rattle spring" and bracket.
Except it is not an anti-rattle spring. It is a return spring to pull the release rod back to the latched position.
RJBrown Avatar
RJBrown Randy Brown
Queen Creek, AZ, USA   USA
According to the factory parts manual.
The side spring is “Anti rattle”
The front spring is “tension”
14E5CBC5-BE19-4D46-AA0D-E5415F9390D1.jpg    47.3 KB
750E0AC6-068B-4C74-8831-6117DC945E0F.jpg    36.4 KB
ghnl Avatar
Mebane, NC, USA   USA
Learn something new everyday!
With #25 disconnected my release rod doesn't go fully forward. (#35 is connected)
3066james Avatar
Amelia, VA, USA   USA
When opening the hood (bonnet), I always have to push the rod back to the latched position. Maybe I need a stronger spring but I think the design of the guide brackets is the problem. There is metal-to-metal friction between the rod and the holes in the brackets on my car.
In reply to # 3863175 by ghnl
JIMBV8 Avatar
JIMBV8 Jim Gibson
Northampton, Northamptonshire, UK   GBR
I've always thought it is an anti rattle spring; it doesn't really exert much of a pull along the release rod, but just holds the rod against the bracket.
And, surely that vendor in Germany has the decimal point in his price one place too far to the right ?
It can't be hard to find a suitable tension spring, the dimension etc aren't critical.
Happy New year, all smileys with beer
