Fan Belt
Fan Belt
  This topic is about my 1959 MG MGA 1500
Richas Avatar
Richas Rich S
Portland, OR, USA   USA
Anyone know the correct belt size for a stock 1500?
Thanks
Rich
Richas Avatar
Richas Rich S
Looks like 10x916 or thereabouts.
rich
Danbgt Avatar
Danbgt Silver Member Dan Suter
Rochester, NY, USA   USA
Hi Rich,
The Moss Motors replacement belt is :
Have Moss Motors 460-990; Flennor AVX10 X 900LA. It says made in Germany.
I am guessing you can use the number to cross reference something of the same size at your local auto parts store.
Dan
Mitchman2 Avatar
Mitchman2 Mitchell Andrus
Mills River, NC, USA   USA
Mine came from Moss with their alternator. I looked and there isn't a size on it.
The Flat Earth Society has members from all corners of the globe.
'30 Model A Ford Town Sedan
'48 MGTC Q Special
'58 MGA roadster
'66 Series 1, 4.2 Jag E-Type OTS
barneymg Avatar
barneymg Barney Gaylord
From my ancient records, I'd give good odds that it is NAPA 09033, which is 36-1/4" for the standard generator. That would be 920-mm (92-cm). If you get it a little too short you may have to dismount the generator to get the belt on. This is s little tricky though, because there were two different generator pulleys for pushrod engines, and two different pulleys for Twin Cam engines, making (I think) four different belt lengths that were standard. There is an CSM on this: http://MGAguru.com/mgtech/care/csm/mg205.pdf
barneymg Avatar
From my ancient records, I'd give good odds that it is NAPA 09033, which is 36-1/4" for the standard generator. That would be 920-mm (92-cm). If you get it a little too short you may have to dismount the generator to get the belt on. This is a little tricky though, because there were two different generator pulleys for pushrod engines, and two different pulleys for Twin Cam engines, making (I think) four different belt lengths that were standard. There are CSM's on this:
http://MGAguru.com/mgtech/care/csm/mg237.pdf
http://MGAguru.com/mgtech/care/csm/mg237a.pdf
Look in the SPL's for the change points and applicable part numbers for the belts.
Belts are generally easy. Run a tape measure around the outside of the pulleys, and it should be within 1-cm of the correct length.
Edited 1 time(s). Last edit at 2017-07-21 02:04 AM by barneymg.
olath Ola T
Oslo, Oslo, Norway   NOR
Gates part.nr. 6217MC is 10 x 925 and was easy to install. Fits my 1622 perfect.
MG TF 1500 1954
MGA 1500 1957
MGB 1963
MGB GT 1967
MG F 1999
MG F 2002
I live in Oslo, NORWAY
Pawtucket, RI, USA   USA
Dear Rich and all other MGA Owners,
To set the record straight, with NO guessing, the original MGA 1500 & 1600 & Mk2 engines (not Twin Cams) had 9.5x900 belts fitted.
Same size as the old VW Beetles, not the modern ones. Currently this size has been changed to 10 x 900 ( a little wider belt) but same length. Possibly this belt is not readily available at parts store, so something close has been obtained.
We just had these specially made with 'MOWOG' printed on the belts with the 10 x 900 size printed on them as well.
Regards,
Cecelia
SCARBOROUGH FAIRE
