Electrical help needed.
tmg.esq Avatar
tmg.esq Tom G
Vero Beach, FL, USA   USA
1954 MG TF
1958 MG MGA
1958 MG MGA 1500
My A has run poorly at times lately, sputtering, cutting out and bucking as though at times its not getting enough spark. Some times it ran fine, especially when started, but quickly had the issue again.
Anyway, replaced the coil, and no luck. Tried to replace the condenser, and now it wont start. And seems to be getting no spark (pulled a plug and held it against the motor, and nothing).
Can someone tell me how the condenser gets wired? Does the wire from it go on top of the plastic washer (with the nut then on top of it), and the other wire attached to the side of the distributor go under the plastic washer and contact the metal of the points?
So is it like a pancakes - nut on top, then below it the condenser wire, then below it the plastic washer, then below that the other wire from the side of the distributor, and below that the points metal?
Any other thoughts on this?
Many, many thanks.
EXLU3453 Avatar
EXLU3453 Colin T
Brantford, ON, Canada   CAN
Check the braided wire from the connection to the condenser. Quite often they can fray and ground out especially when the mechanical advance rotates the point plate. This wire has to be free of all obstacles in the distributor, as it can ground, killing the points.
.. CR
Don MGA 1600 Avatar
Rutland, Rutland, USA   USA
Tom,
Let's build-up.
Start with the post coming out of the base of the distributor points (with the threaded portion for the nut on top) with nothing attached or assembled to it!
Order of assembly:
* Slide the nylon sleeve down to the bottom of post with the flange side facing down.
* Side arced spring over the post so that the ID of the spring engages the OD of the smaller diameter of the nylon sleeve.
* Attach the end of terminal wire from side terminal of the distributor and place it on top of the spring
* Attach the terminal wire from the condensor and place on top of side terminal wire connector
* Now slide the other nylon sleeve down the post-smaller diameter facing down, flange "hat" facing up so that the OD of the sleeve slides into the ID terminals of the condensor side termininal connector holes.
* Attach the nut on top so that it is only contacting the top of the nylon sleeve and nothing else.
Don
tmg.esq Avatar
tmg.esq Tom G
1954 MG TF
1958 MG MGA
1958 MG MGA 1500
Thanks Colin and Don for the helpful info. Your cars look great!
Graham MV Graham Martin
London, london, UK   GBR
Hope you are now sorted but condensers have a bad track record of failure straight out of the box. So if it doesnt work at all after you are sure its fitted correctly, I'd suggest going back to your old one and see if you at least get that rough running fault.
Fresno, CA, USA   USA
Low tension lead, and condenser lead both touch the springy part of the points., than the plastic thingy on top (Notice shoulder), than the nut on top of the insulator. smileys with beer
In reply to # 3899627 by tmg.esq My A has run poorly at times lately, sputtering, cutting out and bucking as though at times its not getting enough spark. Some times it ran fine, especially when started, but quickly had the issue again.
Many, many thanks.
Sir Henry Royce
co-founder of Rolls Royce .
RoyS Avatar
RoyS Roy Sperbeck
deptford, NJ, USA   USA
put a electronic ign in it
Gary E Avatar
Kernersville, NC, USA   USA
Could also be fuel or water there in.. How old is the gas.
bobs77vet Avatar
bobs77vet bob K.
northern Va, VA, USA   USA
I bet the points are grounded…..go to the top of the points where the condenser wire attaches and make sure there a plastic washer isolating it from the stud.
