Cutting a hole in the transmission tunnel.
Midlothian, TX, USA   USA
I want to add a cup holder just in front of the armrest in my MGA. The problem I have is that my favorite travel cup is just a little too tall to shift comfortably. I was wondering if it would be acceptable to cut a hole in the transmission tunnel to recess the cupholder a bit. Your opinions matter.
20190309_103004.jpg    26.4 KB
59mgaguy Avatar
59mgaguy John Terschak
Wakeman, OH, USA   USA
1930 Ford Model A "Jenny"
1959 MG 14/28 "Jessie"
1974 MG MGB "Oooops"
Randy,
I would advice not to cut. Do a search for, "New MGA console--Opinions please" here on MGE. the posting was done by oberRo. Who is Robert Clark.
https://www.mgexp.com/forum/mga-forum.2/new-mga-console-opinions-please.3120954.3120954/#msg-3120954
John
While that is a great solution, the issue I have is that my car sports a 1973 MGB 1800 engine and transmission. This forces the shifter slightly forward thus tucking the cup further under the dash making it difficult to retrieve.
20190309_111716.jpg    26.5 KB
copernicus Avatar
copernicus Nick Kopernik
Cold Spring, CT, USA   USA
I tried a center console cup holder, it was awkward. I switched to using the door pocket to hold any cups/bottles/cans without having to resort to any cutting or fabricating. Just need to use a bit of packing to make a nest for the cup so it doesn't move; you can also use a commercially available cup holder as a receptacle. Just be careful and avoid slamming the door with a cup in it!
Rob Z Avatar
Rob Z Silver Member Rob Zucca
Camarillo, CA, USA   USA
1960 MG MGA
My favorite still.....a roll of gorilla tape on the floor of the passenger side. Sticks to the mat. Idea stolen from Barney’s site.....works a treat.
C8074626-5767-46FE-9DF6-507EBFE2B44A.jpeg    26 KB
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
If you cut a hole in the tunnel, the cup will wind up sitting on the gearbox, not much clearance.
Herb
Gary E Avatar
Kernersville, NC, USA   USA
I made this and it works great. I see your gear shift is different so that may not work.
IMG_1333.JPG    17.2 KB
IMG_1327 - Copy.JPG    49.6 KB
IMG_1322.JPG    22.7 KB
dominic-ch Dominic Clancy
zurich, zurich, Switzerland   CHE
If you look at the attached picture of the same box installed in an MGB you will see that you have no space underneath that point in the tunnel
s-l1600.jpg    33.6 KB
JRSCA Avatar
JRSCA Silver Member John Smith
Woodstock, ON, Canada   CAN
Ain't going to work if the cup ends up sitting on the tranny.
Find a shorter travel cup.
John
Rob Z Avatar
1960 MG MGA
Randy said “ahead of the armrest”. I’m not familiar with the dimensions of the 73 box, but in an A that’s in propshaft territory.
Randy, you might want to crawl under the car and see how much space there is above the propshaft for your 1-1/2 depth. The U joint is also in that area. While the hole may aid in greasing that pesky front U joint zerk, it may be pretty tight in clearance.
marquismarque Mark Lawton
Coquitlam, BC, Canada   CAN
1968 MG MGB "Killer B"
Really!!!, you want to scar your mga for a cup holder?. These cars were built for the pleasure of driving, not for lounging around drinking tea! Drive your car to the teashop of coffee house, have your drink then get in your car and drive it the way it was meant to be driven.... in such a way that you need both hands to steer/shift/ hang on, your cup would fly out of the cupholder anyway. If you want a car that will hold your cup while you casually putt around then there many other, non impressive, basic transportation style cars available.
Just my opinion,
5 mgbs
1 midget
1 e type
1 v8 powered xj6
Tbird Avatar
Tbird ET Taylor
Land O Sky, NC, USA   USA
I believe you'll hit the tunnel stiffening brackets if you try to cut into that area.
Would be surprised if there is enough room to cut a circle large enough.
(from Barney Gaylords site)
Think I'd go with Gary's design - maybe with some velcro straps to hold it to the carpet and keep it from tipping or posts that go all the way to the floorboards.
Otherwise x2 with Nick on the door pocket.
Fresno, CA, USA   USA
RANDY: Your CUP, your CAR>????? I have made about six of these for people.
In reply to # 3905659 by Randy H I want to add a cup holder just in front of the armrest in my MGA. The problem I have is that my favorite travel cup is just a little too tall to shift comfortably. I was wondering if it would be acceptable to cut a hole in the transmission tunnel to recess the cupholder a bit. Your opinions matter.
Sir Henry Royce
co-founder of Rolls Royce .
MY MGBGT AND LAMP 015.jpg    65.7 KB
mgainaussie Avatar
mgainaussie Gary Lock
Gold Coast, Australia   AUS
Brilliant idea Joe. You could also just find another windscreen washer bottle holder, and maybe bolt it to the door hinge pillar area?
Rob Z Avatar
1960 MG MGA
Wow....that’s a great idea to use a Tudor bottle bracket. And period too! They attach from the side or the bottom. Perfect!
In reply to # 3906549 by mgainaussie Brilliant idea Joe. You could also just find another windscreen washer bottle holder, and maybe bolt it to the door hinge pillar area?
