Rear Brakes... I'm stuck! A little help please?
73midget Avatar
73midget Chris Edwards
Garland, TX, USA   USA
In reply to # 3907117 by PeterC The adjuster ends of both shoes appear to be resting on the adjuster housing rather than into the wedgies slots. Just pry one shoe out and take a look.
Peter c
This. I don't think the shoes are properly placed.
+1 Yes No Thank
refisk Avatar
Frankenmuth, MI, USA   USA
I disagree, the cutback DOES matter. It doesn't matter in terms of Rob's problem in getting the drums back on, but it does matter. Think about it, the shoes only move on one end when you push the pedal. We have a single cylinder with two pistons. The adjuster end of the shoes do not move out when you push on the pedal, the shoes pivot on the adjuster. The arc of the shoes may match the brake drum, but only one end moves out to contact the drum. Where the shoe contacts the drum makes a difference in braking effectiveness. There is a reason the brake system manufacturer used shoes with a cutback. http://www.engineeringinspiration.co.uk/drumbrakes.html
In reply to # 3907276 by jmac In my humble opinion, IMHO, (and "humble" might be a bit of a stretch of the truth) the cut back looks more like 3/4" rather than a full inch but the cut back shouldn't matter. The pads should be the same curvature as the drum so whether you have a cut back or not should not make a difference especially with the adjuster all the way out.
It appears to me that if the adjuster is all the way out and the 2 angled pieces are touching, or almost touching in the center that the shoes should fit into the each side of the adjuster housing further than they are. There is a bit of a tab that sticks out on the adjuster piece, I think to stabilize it in housing, I think your shoes are riding up on this tab and not down into the adjuster piece completely. (see the picture below)
+1 Yes No Thank
Richard D Avatar
Knoxville, TN, USA   USA
….. disregard
Edited 1 time(s). Last edit at 2019-03-12 11:18 AM by Richard D.
RobbyJoe Avatar
RobbyJoe Rob Heib
Stanwood, WA, USA   USA
Well, a good nights sleep and rested eyes helped tremendously. As many here suspected, my problem was one of the shoes not sitting correctly in the adjuster slot. Being on jack-stands, I had to do a little contortion to get a good look, and sure enough one of the shoes was sitting on the lip of the wedge and not down on the correct “shelf”. Brake drum slid right on without issue! Now I can do the other side!
Thanks to all for saving me from an embarrassing call to NW Imports when it was my issue all along! At least this experience will serve as a great learning experience for me. Now I just have to do the right side, replace the flexible hose, bleed the system, adjust the hand brake, and I’ll be set to drive!
refisk Avatar
Glad you got it Rob. thumbs up
In reply to # 3907516 by RobbyJoe Well, a good nights sleep and rested eyes helped tremendously. As many here suspected, my problem was one of the shoes not sitting correctly in the adjuster slot. Being on jack-stands, I had to do a little contortion to get a good look, and sure enough one of the shoes was sitting on the lip of the wedge and not down on the correct “shelf”. Brake drum slid right on without issue! Now I can do the other side!
+1 Yes No Thank
jmac Avatar
Greenup, IL, USA   USA
1971 MG Midget "Joy Ride"
1978 MG Midget "Therapy"
1978 MG Midget "(SOLD)"
In reply to # 3907351 by refisk I disagree, the cutback DOES matter. It doesn't matter in terms of Rob's problem in getting the drums back on, but it does matter.
Rick, I wasn't saying the cutback doesn't matter in the sense of operation or proper installation. I meant, as you said, in terms of Rob's problem it doesn't matter.
Sorry for the confusion.
Rob, glad you got it figured out!!!! This is a great forum, isn't it! thumbs upthumbs upthumbs upsmileys with beer
JMac
JMAC Engine Shop
http://www.jmacengineshop.com
Edited 2 time(s). Last edit at 2019-03-13 08:14 AM by jmac.
RobbyJoe Avatar
RobbyJoe Rob Heib
Yes indeed, this place is awesome!
