oil pressure
Diane Avatar
Diane Diane Linsell
melbourne, victoria, Australia   AUS
I have a 1968 MG Midget 1275 - at idle and 800rpm my oil gauge reads 80 lbs and engine warm. I am using Penrite classic medium oil, if I use a light oil will that bring the oil pressure down? with outside temperature at 112 degrees F.
Thanks
bev sleet Avatar
bev sleet Bev S
use 20/50 weight oil , the higher the oil pressure the better, you seem to have a good engine at 80 lbs and 112f
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
Yes, A series engines are supposed to run higher oil pressure than is common. if you wish, lower viscosity oil wouldn't hurt you but may be more prone to leak or have it consumed.
Kurt
Kurt, can you explain/elaborate?
In reply to # 3890659 by S1 Elan Yes, A series engines are supposed to run higher oil pressure than is common. if you wish, lower viscosity oil wouldn't hurt you but may be more prone to leak or have it consumed.
Kurt
ice Avatar
ice Gold Member Larry Ice
Lawrenceville, GA, USA   USA
Diane, Guys, seems like 800rpm and warm engine with 80psi is a bit much. What is the PSI at 3000rpm? Might check your oil pressure gauge against another oil pressure gauge. Most owners desire more psi for their cars but you have the opposite. A bit more background on the car would be helpful.
Diane, I see that you put the year of our car in the text but it would be super for everyone if you would put the car year into your profile so the year would automatically show on every post you make. Takes but a moment and you're done with it.
Iceman
Atlanta GA
60 AH MK1
62 AH MKII
67 Midget
71 Midget
Akron, Ia., USA   USA
In reply to # 3890883 by dickmoritz A series engines are supposed to run higher oil pressure than is common.
Kurt
Yes, I should have been clearer. When I was growing up around US vehicles and British Vehicles the British vehicles always ran far higher oil pressures. Maybe the American vehicles were just more worn!winking smiley
Thanks, Kurt. I misunderstood your original post and thought you were suggesting that A series engines ran higher oil pressure than B series engines.
My experience agrees with yours, that older American cars ran lower oil pressure than British cars, perhaps because most all were six or eight cylinders, thus having more rod and main journals where oil/pressure could escape...
In reply to # 3892000 by S1 Elan
Kurt
