Mounting the flywheel
LKNHTH Earle Wingate
Pittsfield, NH, USA   USA
After significant delay caused by a 150 mile move and the building of a house, I'm back to reinstalling a freshened 1275 into one of my '72's. Any magic to reinstalling the flywheel? Nice clean surface, just bolt her on and have at the clutch?
E. F. Wingate, III
The Williwacks of Maine
'59 MGA (x3)
'72 Midget (x3)
PS. Anyone need bits or projects for the above?
rhodyspit75 Avatar
rhodyspit75 Ernie Connor
Cumberland, RI, USA   USA
What you said plus you should have a lock tab under the bolts. You fold the tab up against a flat on the bolt after you torque it down. https://mossmotors.com/locktab-flywheel?assoc=47263
Davenport, IA, USA   USA
In reply to # 3908607 by rhodyspit75 ....you should have a lock tab under the bolts.
PN 12G982 $5
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
http://kirks-auto.com/
Moss distributor/UK importer
refisk Avatar
Frankenmuth, MI, USA   USA
Loc-Tite on the bolts, 40 pounds of torque.
jlpor Avatar
jlpor John Parker
Portland, OR, USA   USA
Just did this and what they said. Locktite, lock tabs and torque wrench. Really good time to think about an oil seal kit.
jp
rhodyspit75 Avatar
In reply to # 3908650 by jlpor Just did this and what they said. Locktite, lock tabs and torque wrench. Really good time to think about an oil seal kit.
jp
Just out of curiosity why loctite and lock tab? Doesn’t the tab prevent the bolt from turning?
refisk Avatar
I just use Loc-Tite, no lock tab.
In reply to # 3908722 by rhodyspit75
jp
Edited 1 time(s). Last edit at 2019-03-14 05:37 PM by refisk.
[/quote]
[/quote]
It does and does well and best, IMHO. Locktite is simply redundancy.
Regards,
Robert Kirk
kirkbrit@yahoo.com
rhodyspit75 Avatar
Belt and suspenders smileys with beer
jlpor Avatar
jlpor John Parker
If you are installing an oil seal kit, the locktite is more of a sealant to keep oil from passing through the bolts. In the past I have only used the tabs.
jmac Avatar
Greenup, IL, USA   USA
1971 MG Midget "Joy Ride"
1978 MG Midget "Therapy"
1978 MG Midget "(SOLD)"
Make sure the pilot bushing is still in the end of the crankshaft.
JMac
JMAC Engine Shop
http://www.jmacengineshop.com
mg-john Avatar
mg-john Gold Member John Hewell
Walhalla, SC, USA   USA
I use Loctite and no locking tab. The locking tab is made of softer material than the flywheel (more on Aluminum flywheels in a minute) or the bolts. The tab material can "squish out" thus reducing it's thickness. The end result is the holding force of the bolts is lessened. The flywheel can then begin to wobble.
I use an aluminum flywheel on my race car. I Use ARP bolts with hardened washers to spread the load on the flywheel. No locking tab but generous blue Loctite. Not had a loose flywheel in 11 years of racing. Takes an impact wrench to remove.
John
John
I make specialty products for our Little British Cars. Shown is my race car at Daytona. I have the following products: timing chain cover stiffeners for MGB, A Series Spridget, and 1500 MG Midget and more.
In reply to # 3908727 by refisk I just use Loc-Tite, no lock tab.
X2, lock tabs were a cruel joke that is long out dated.
