Interesting Axle gear oil leak......
jlpor Avatar
jlpor John Parker
Portland, OR, USA   USA
Background:
Finished a 5 speed transmission conversion. Initial tests all positive. Took the car out for a good test, Highway speeds a fun twist road home. All is well. Noticed the left rear tire was low and stopped to fill it to get home.
Removed left rear tire to take it to the shop. Later noticed a puddle of MT90 gear oil under the hub. Is it possible the lug nuts helped hold the seal on the axle? is there any relationship to going really fast the first time to causing a leak at that point?
Pulling it apart this weekend to replace the seals and gaskets (both sides).
Just wondering???
BTW - I love the 5 speed. I think it still could use a 3.7 though.
Thanks guys,
John
Edited 1 time(s). Last edit at 2019-03-13 01:40 PM by jlpor.
westfield7 Silver Member Michael Wooten
1983 Westfield Seven "Green Car"
In reply to # 3908092 by jlpor ... Is it possible the lug nuts helped hold the seal on the axle? ...
Yes. Although there is a screw that holds the axle shaft to the hub the lug nuts supply the main sealing force.
66jalopy Avatar
66jalopy Phillip Jolliffe
Lake City, FL, USA   USA
Yes, the lug nuts hold it if the screw not tight enough. I tighten the screw by putting a couple washers on at least two studs, put two lug nuts on and tighten, now tighten screw. It has worked for me, you may need to do the same to loosen it again.
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
Your brake drum should be pretty well oiled now so you might as well pull it, clean it, and tighten the screw.
Kurt
jlpor Avatar
jlpor John Parker
I just purchased the kit from Moss. I am going to look at the bearings also. Any tips?
Thanks Kurt
GeorgeOhr Nonya Business
Yes, confused, USA   USA
Take that stupid gasket and oring and throw them both away and us 3M Ultra Black instead and it’ll never leak again. Get new shoes too as youlll never get the oil out of them.
Akron, Ia., USA   USA
Hopefully the shoes aren't oiled yet, George. If he just pulled the wheel and noticed the oil dripping out there is probably not much on them yet. If they aren't saturated I've been able to clean them up with gasoline or turpentine. If saturated George has the plan for the shoes.
Kurt
here is an article from the Library which might be useful, regarding rear wheel bearings and so on
https://www.mgexp.com/article/midget-rear-axle-knowledge.html
In reply to # 3908379 by GeorgeOhr Take that stupid gasket and oring and throw them both away and us 3M Ultra Black instead and it’ll never leak again. Get new shoes too as youlll never get the oil out of them.
Yep, I also recommend after sealing up the hub and axles to bolt the wheels on as the RTV dries. I modded my SCCA Sprite race cars axles,and hub to have 4 screws, instead of one. George's recommendation of Permatex Ultra Black is key, sealing up Spidget hubs and axles is what sold me on the this RTV, the Right Stuff is essentially the same stuff, just dries faster, I always gave UB 24 hours to fully cure.
New Hyde Park, NY, USA   USA
Start by replacing the rear hub oil seals. If they are bad you will never get rid of the leaking oil.
...since the leak began only after a wheel was removed, and that leak is a known characteristic of this axle design, when a wheel is removed, I don't suspect the hub oil seals have anything to do with it.
When I first started playing around with Sprodgets back in the 70's I can't count how many hub gaskets and o rings and shoes for that matter
before I realized there was a inner oil seal.. Live and learn I guess
jlpor Avatar
jlpor John Parker
Thanks Hap,
That engine we built is a monster (for a 1330). Thanks for the great help. I still think she could use a 3.7.
jp
atm92484 Avatar
atm92484 Andrew M
Pittsburgh, PA, USA   USA
In reply to # 3908439 by Speedracer
I went to 4 bolts on the racecar and stopped using RTV, the stock gasket, and stock o-ring and only use an x-ring in the correct diameter. Always having at least two bolts on opposite sites combined with the lower sealing forced required for the x-ring has worked really well and I don't have to clean up RTV or other goop when I pull an axle.
When the time comes to remove the street car's axles, I'll give them the same treatment.
1978 MG MGB
