Indicator stalk
71 MG Midget Mel Wilby
EYE, Suffolk, UK   GBR
Hi i am a reasonably new member and i am now the owner of a 1971 Midget,the problem i have is this,would the horn have been worked on the indicator stalk or by the horn push on the steering wheel all info would be greatly recievedMany thanks Mel
noahnsteph Noah Corr
Omaha, NE, USA   USA
I may be wrong but I believe the horn should the steering wheel for a 1971. I think only the late models (78-79?) with the full vinyl covered steering wheels used the turn signal stalk for the horn.
+1 Yes No Thank
  71 MG Midget thanked noahnsteph for this post
flat350 Avatar
flat350 Steve Alleman
Schaumburg, IL, USA   USA
My 71 is steering wheel..............
1971 MG Midget MKIII
+1 Yes No Thank
  71 MG Midget thanked flat350 for this post
CountBasey Avatar
CountBasey Silver Member Thomas Basey
Brunswick, OH, USA   USA
1976 MG Midget 1500 "Opus"
Yep - Horn knob. My steering wheel is off of a 71 (at least that’s what the seller told me).
Thomas (Count) Basey
_______________________________________________________
+1 Yes No Thank
  71 MG Midget thanked CountBasey for this post
Foz66 Avatar
Foz66 Fraser B
Chester, Cheshire, UK   GBR
I'm new to this group and to my Midget too however just sorted horn and indicator stalk problem.
Enclose a photo of my 74 with the stalk before replacement with steering wheel removed and you can see the copper clip that rubs on the back of the steering back of wheel and powers the horn. The horn push completes the circuit to earth on the steering column. Note that the clip on the column (cancels the indicator after turning) was not in the correct position, just one of the problems I needed to fix.
Second picture shows the new stalk and horn contact. Ignore the lower one in my hand, just comparing old one with new one. Old one so worn struggled to get it to touch back of steering wheel.
Hope this helps.
Fraser
file1-3.jpeg    36 KB
file-5.jpeg    27.9 KB
+1 Yes No Thank
H i many thanks for the reply problem now solved thanks
Red midget Avatar
Red midget Gold Member Robert G
Honesdale, PA, USA   USA
My 70 uses the stalk, but it was built in 69. Many parts I need are for a 69, and some are from a70 and occasionally a part from a 64. Who knows what you need. Just part of the puzzle
