I see alot of articles on HOW to do it. But how do I know if I NEED to do this?
I do have bachelor lean, but that isn't unusual.
The car has not bottomed out or given me cause for concern, other than the bushings are worn which I am replacing. Thoughts?
Thanks
Edited 1 time(s). Last edit at 2019-02-05 07:17 PM by dogeddie.
how do I know if I should replace my leaf springs?
Posted by dogeddie
Kaukauna, WI, USA
![]() 1975 MG Midget 1500
Feb 5, 2019 06:47 PM
Joined 1 year ago
Knoxville, TN, USA
Feb 5, 2019 08:02 PM
Joined 19 days ago
What does your car set like looking at from the side? Does it squat in the rear more than your liking?
You could get the springs re-arched at a spring shop if you wanted to raise the ride height a bit. They could even address the bachelor lean as you refer to it.
Kaukauna, WI, USA
Feb 5, 2019 09:32 PM
Joined 1 year ago
In reply to # 3886722 by Richard D
Thanks Richard. I have a pic of it in my photo above. I think the height is ok except for the lean to the left. Maybe I'll wait and just do the bushings and see what I have then.
GeorgeOhr
Nonya Business
Yes, confused, USA
Feb 5, 2019 09:39 PM
Joined 1 year ago
S1 Elan
Kurt. Appley
Akron, Ia., USA
![]() 1964 Lotus Elan
Feb 5, 2019 11:43 PM
![]() Joined 6 years ago
Most of the sag comes from the plastic spacers between the leafs wearing out. I have rebuilt several sets with new strips with the assumption that replacement parts now days are seldom as good as the original. You can compensate some for the bachelor lean by swapping springs from one side to the other. Big job so if what you have isn't too bad might not be worth it. Leaf springs aren't really worn out till the plastic wear strips are gone and the leafs have worn a deep indentation into the adjoining leaf.
Kurt
Kurt
Kaukauna, WI, USA
Feb 6, 2019 09:30 AM
Joined 1 year ago
A on a shoe string
Peter Stevenson
Aubusson d'Auvergne, Auvergne, France
Feb 7, 2019 03:22 AM
Joined 1 year ago
I knew the springs needed changing the day I had an overweight passenger who liked talking. There was a light clunk and suddenly the steering wheel adopted a slightly different angle to keep it straight. My passenger never missed a syllable. Not wanting to alarm him, I drove carefully the last 3 miles, dropped him off home and ordered new springs that evening.
Kaukauna, WI, USA
Feb 7, 2019 07:26 AM
Joined 1 year ago
In reply to # 3887301 by A on a shoe string
Ha ha ha!
ChatltonLatchford
Bernard Spilsbury
Orihuela Costa, Alicante, Spain
![]() 1977 MG Midget 1500 "Midge"
Feb 13, 2019 02:43 PM
Joined 5 years ago
Has anyone ever simply swapped the springs over from left to right and vice versa to counteract "batchelor's lean"?
Feb 13, 2019 06:30 PM
![]() Joined 10 years ago
If you swap both front and rear springs it should work.
Many have tried swapping only the rear leaf spring but most find that, alone, doesn't suffice.
N
N
S1 Elan
Kurt. Appley
Akron, Ia., USA
Feb 14, 2019 08:48 AM
When ever I was working on the rear springs I was working on the whole suspention so, as Norm says, the front's should get swapped as well. I have replaced the fronts with stiffer springs and heavier sway bar which I adjusted to compensate a little for the bachelor lean as well.
By the looks of the general public, to compensate for the lean you shouldn't have much trouble finding a rather heavy girl friend!
Kurt
Kurt
Abington, PA, USA
![]() 1976 MG Midget MkIV "Rodney"
Feb 14, 2019 07:29 PM
Joined 6 years ago
Hi Andy,
Before you go and start pulling apart your rear springs it may be wise to check and test your front and rear shocks all around. They are lever shocks and sometimes need a bit of help hydraulic fluid wise. There are procedures for testing the shocks, but I don't have them handy. And, no, the procedures are not just bouncing the fenders up and down. Rather, it is a measure of the shocks' resistance to compression. The shocks "want" to be at a certain point when not under added load, and that point is one which keeps the car rather level on level ground when unoccupied, and is irrelevant of the springs. I had the procedure years ago, but not now. It's the testing used to see if the shocks need to be replaced or rebuilt. Someone else in the Forum may have it.
Regards,
Richard
Regards,
Richard
refisk
Rick Fisk
Frankenmuth, MI, USA
Feb 14, 2019 07:55 PM
![]() Joined 7 years ago
The shocks have nothing whatsoever to do with ride helght. All they do is dampen spring oscillations, and in the case of our Spridgets they do double duty as the front upper suspension link. But the springs are the only thing that determines ride height.
In reply to # 3891886 by Richard P. Senatore
Hi Andy,
Regards,
Richard
Regards,
Richard
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
