Electric Fuel Pump On 79 1500 Midget
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
Greetings everyone.
I am getting close to finishing the complete rebuild of my 79 1500 Midget and I didn't like the routing of the fuel lines to the mechanical pump to the carbs and their lag when starting up after longer periods.
Especially since I put twin SU's on the car.
So I sourced a ECCO pump from Moss (377-176)
Besides the pump needing to be installed on the bulkhead, you need to massage the fuel lines a little and run a power source back to the pump.
I hope the pictures help (you have to rotate the picture 90 degrees for true orientation)!
Edited 3 time(s). Last edit at 2019-03-15 07:38 PM by bleteaches6.
DSCN3193.JPG    39.7 KB
377-176_1.jpg    12 KB
GeorgeOhr Nonya Business
Yes, confused, USA   USA
That’s where I have my Carter
bleteaches6 Avatar
George, I hadn't thought about it until I needed to, but it was sure nice of MG to leave that open cavity behind that bulkhead so I could reach my fat hand up in there.
The only problem is that bulkhead seems to amplify noise like The top of an acoustic guitar. It sounds like a have a small outboard motor running in my trunk. The god thing about that is I am tell when my brake lights aren’t working but the sound of the fuel pump. winking smiley
bleteaches6 Avatar
Good catch on the noise George. If it is too loud, I have some sheet rubber that I used on my MGA pump for the same reason and I can put a little strip behind it.
It won’t help, mine has rubber mounts
bleteaches6 Avatar
The thick rubber that I used on my MGA worked a little, but you are right, you can't isolate it all. I wonder if a little Dynamat on the inside wall would help reduce the drumming effect.
1974MGMidget Avatar
Grayson, GA, USA   USA
The Dynomat is worth a try if you have some, but probably won't be effective enough. I mounted a Facet on the rear bulkhead and originally used the transmission mount for a MGB (Moss 413-050). Its sort of like an isolation mount, but the rubber is very hard, and it did not work well either. Probably because its designed for a transmission which is much heavier than a fuel pump! I recently remounted it with some of these isolation mounts that are made out of softer rubber and I've never heard such a quiet Facet! You can get them at Summit, and Pegasus Racing and other places, I'm sure.
fuelpumpmounted.jpg    47.2 KB
fuelpumpmount.jpg    66.1 KB
bleteaches6 Avatar
That's a good idea Jack!
terryke5hwe Silver Member Terry Halbert
Rogers, AR - Arkansas, USA   USA
1978 MG Midget 1500 "Midge"
1979 MG MGB "Money Pit!"
I put an Ecco pump on my MGB and it is super quiet and works well with the S.U.'s
