On the ‘72 doner car I picked up came a nice looking set of American racing spoke wheels, they’re very weathered and oxide. In need of a good cleaning,
The only thing I found on some old threads was using oven cleaner or simply green.
These are the best out there?
Some recommendations would be a great help,
Thanks
Aluminum wheel cleaning
Posted by Cooper101
Cooper101
John Williams
Wilton, NY, USA
![]() 1976 MG Midget 1500 "007"
Jan 19, 2019 08:55 PM
Joined 11 months ago
Floyd, VA, USA
Jan 19, 2019 09:05 PM
![]() Joined 3 years ago
There are numerous aluminum and mag wheel cleaners available at most parts stores.
Grayson, GA, USA
![]() 1974 MG Midget MkIII
Jan 20, 2019 06:53 AM
If the wheels are rough cast/textured, soda blasting will clean them really well. But, any polished portions need to be protected. Cleaners, as mentioned, along with a stiff brush will clean up most smooth alloys. Do you know what model wheels they are?
GeorgeOhr
Nonya Business
Yes, confused, USA
Jan 20, 2019 07:15 PM
Joined 1 year ago
tomshobby
Tom Smith
Windsor, WI, USA
Jan 20, 2019 09:37 PM
Joined 9 years ago
Greenville, SC, USA
![]() 1967 MG MGB Racecar "The Biscuit"
Jan 21, 2019 08:26 AM
![]() ![]() ![]() ![]() ![]() Joined 12 years ago
In reply to # 3877927 by tomshobby
Just make sure they are not magnesium.
And if they are magnesium, then best to keep them retired.
MG/ Triumph Performance Street/Race Engines -
Cylinder Head Porting -
Modified SU HS Carbs -
DIY Engine Rebuild Kits With Free Tech Advice -
VTO alloy wheels for British Sport Cars, and others
pigpen
Tom Springer
Federal Way, WA, USA
Jan 21, 2019 12:10 PM
Joined 6 years ago
Knoxville, TN, USA
Feb 5, 2019 09:20 AM
Joined 13 days ago
A friend of mine that was in the car wash business used to make his own aluminum cleaner. He would use a bar of the White jewelers rouge, grated fine with a garlic or cheese grater, Ronsonol Lighter fluid, and Rain-ex wind shield liquid.
He would put the entire grated bar of rouge along with (iirc) roughly 2 parts rain-ex to 1 part lighter fluid into one of those old style refillable plastic ketchup type squeeze bottles.
Drop a 3/8 or 1/2 stainless nut into the bottle to act as an agitator like a spray paint can has. Shake it up until the rouge dissolves into a smooth enough consistency to squeeze out the bottle. I like mine a bit on the thinner side. It is a bit of trial and error until you find what works best for you.
The rouge and naphtha cleanse extremely well, and the rain ex seals the aluminum surface somewhat to resist further oxidation. I have been using it on aluminum for years. You will go through a lot of rags as it will blacken them up fairly quickly.
I would suggest that if anyone decides to try it, make up a small amount and play with the mixing ratios a bit on non critical parts to see if you think it will work for your needs. As it thickens or starts to dry out over time, which it does, just add more liquid to the mix and shake it up again.
Richard
Richard
Greenville, SC, USA
Feb 5, 2019 09:34 AM
In reply to # 3878220 by pigpen
Pics? I have a hankering for American Racing wheels...
We have the Retro 4 ( AR Libre style ) for the Spridgets
Edited 1 time(s). Last edit at 2019-02-05 09:35 AM by Speedracer.
Sprite1956
Roger Parry-Jones
Melbourne, Victoria, Australia
Feb 6, 2019 05:04 AM
Joined 3 years ago
Guys,
A lot of aluminium polishing products contain hydrofluoric acid (in small amounts). This is very effective as it removes aluminium oxide as it polishes to the bare metal on heavily weathered alloy wheels. Car detailers swear by the stuff. However, even in concentrations as low as 5% it may be absorbed through skin and eyes and particles can be ingested if you use power tools to assist. Hydrofluoric acid binds with calcium and is a systemic poison to the central nervous system. I attended an investigation where a small 70% solution spilled on a lab. workers arm, leading to an emergency amputation. Don't forget to wear all appropriate safety gear! Alternatively, soda blasting at a local workshop could be easier and safer. Oh, you'll need to clear-coat or paint the wheels afterwards.
Sorry to be 'anal' but I've seen bad things happen to nice people over 20 years. Don't let it be you.
Roger
Roger
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
