advice on Oil Filter adapter Midget 1500
beal Bill bennett
Melbourne, FL, USA   USA
Hi: I need a little advise on the midget / triumph 1500 oil filter adapter. Is it required? I have seen some pictures of motors that are not using the adapter. What is it's purpose and can it be deleted? I am using this motor in a different application and it will make the steering linkage easier if I can delete it. Thanks for answering Bill
Abington, PA, USA   USA
1976 MG Midget MkIV "Rodney"
Hi Bill, I really don't know anyone with an MG who uses the old style filters. They use regular spin-on filters, hand-tightened. All you need is the screw adapter, and they are common and cheap. In fact my '76 came with the adapter when I bought it new from the dealer. It's just a two sided screw-in with threads on one side for the block receiver and on the other a normal screw size for a filter. Don't know your application since you didn't say what it is, but the spin-on filter is a lot shorter than the old ones and clears everything in Midgets and Spits that I've had. Is this your first MG/Triumph?
Regards,
Richard
GeorgeOhr Nonya Business
Yes, confused, USA   USA
I took mine off as I see no reason for it. All you have to do is unscrew the nipple in the adapter and it’ll screw right into the block once you get the adapter off.
1958 MG Magnette ZB Varitone
