71 Midget front end noise.
Posted by padutchmidget
padutchmidget
Richard W
Landisville, PA, USA
![]() 1971 MG Midget MkIII
Feb 3, 2019 08:00 AM
Joined 3 years ago
I am going to put a socket on the shock mount bolts and now the rack mounting bolts as well. Thanks again to all for the advise. If everything checks out I will start the front suspension diagnostic process.
Feb 3, 2019 09:11 AM
![]() Joined 10 years ago
x2, no need for grade 8 for it, in fact, grade 8s only come in fine thread and you want the corsest available thread to make the process go quickly (put a little oil on the threads to prevent galling, then use a deep socket on a power driver to zip the nuts up/down)
padutchmidget
Richard W
Feb 3, 2019 09:23 AM
Joined 3 years ago
Home depot hardware run, bolts and maybe some 3M glue for my convertable top. Thanks
littlecars
David Bassett
Nashville, TN, USA
![]() 1965 Chevrolet Corvair "Ski Team Transport SOLD!"
1965 MG Midget MkII "Buffoon" 1966 MG Midget MkII "Swiss Cheese...SCRAPPED" 1970 Triumph Spitfire MkIII "Tamara's Turd... SOLD!!!" & more |
Feb 5, 2019 09:39 AM
![]() Joined 7 years ago
In reply to # 3885149 by NickC
Five inches long.
I would add the Autobooks manual written by Kenneth Ball, #745. The illustrations are clear and precise, unlike the muddy reproductions in the Chiltons. It's the book I carry in the boot in case I break down
Agree totally about the Autobooks Kenneth Ball manual. Keep one torn and grease covered one in the car. A clean one to refer to in the shop or from my easy chair. Several used ones on eBay at the moment. Make sure the Spridgets covered go all the way to your year. Many editions were published over the years.
As far as the bolts being 5 inches long...I have to ask aren't the coils extended close to 6-8 inches on a stock Midget? Don't you want the bolts to be at least that long? 5 inches seems like it would make more trouble when removing the springs.
Fredonia, NY, USA
Feb 5, 2019 10:17 AM
Joined 5 years ago
Yes, 5 inches is a bit short. They were the max. length available at HD, but I could have gone with a 3 foot length of threaded rod, chopped up into a couple of suitable lengths. In practice though I found that most of the pressure was off the lower A-arm using the short bolts. Back in the day when I had a fully equipped shop I used a hydraulic spring compressor. Funny, it's like matching book ends to my working life. I started my career as a mechanic aged 15 using improvised tools and now I'm ending it the same way.
Nick Cherau
Fredonia, NY
1971 Midget MkIII "Little B"
2004 Honda Civic Si Hatchback "200K and still a blast"
Nick Cherau
Fredonia, NY
littlecars
David Bassett
Nashville, TN, USA
Feb 5, 2019 10:44 AM
I used coarse unithread for my aborted spring swap project a few years ago. Still have them in my improvised tool drawer. There have been many "better mousetrap" moments for me, trying to restore DD on a shoestring budget.
Sprite1956
Roger Parry-Jones
Melbourne, Victoria, Australia
Feb 6, 2019 04:44 AM
Joined 3 years ago
Nick,
I thought the Sprite Midget steering racks up to 1275 model were not greased but were oiled? Not sure about the later Triumph racks. I'll check out John Twist's Youtube 'library'.
Roger
Roger
Feb 6, 2019 06:04 AM
Roger, you are correct, the Morris rack used from '58~'74 takes 90W oil. Only the Triumph rack, used from '75 ~'79 takes axle grease.
However, corn head grease is pretty unique, it "sits" like a grease, and it "moves" like a heavy oil. My Morris rack leaked its oil at a pretty regular rate, even after having John Twist fit new seals. Then I tried refilling it with corn head grease, now its outside and the body around it remain dry. The corn head grease is pretty interesting stuff to see and feel, how it behaves. On the recommendation of someone on this forum, some years ago, I tried it and it seems to be working for me (so far).
It moves like an oil, when the agitation of the rack moving "liquifies" it, to do its job, and when siting still, it sits without moving by gravity, so it doesn't leak out.
N
N
Sprite1956
Roger Parry-Jones
Feb 6, 2019 06:38 AM
Joined 3 years ago
Norm,
Thanks for the feedback. Over the years many people have assumed that the 'grease nipples' ( you call them zerks?) meant grease was required, and high temperature lithium bearing grease just didn't do the job as it fails to migrate to all components subject to wear. I've stripped down a few that showed serious wear that the owners had 'maintained' regularly. I understand the irritation that comes from rack oil leaks but, interestingly, most I've seen have been due to damaged gaiters, lack of lubrication and exposure to dirt. Some replacement rubber components available nowadays don't last sixty years, especially when exposed to EP90 oil. Who would have imagined? Anyway, any lubrication is better than none, unless you have to rebuild it in 5 years. Not many people would have a pressure oil gun, as opposed to a grease gun. The standard early Spridget steering rack is a beauty of a design, 2.3 (?) turns lock to lock and usually perfectly reliable for many years.
I've never heard of 'corn grease' and doubt if it's available here but I'm always interested in something that makes our babies more reliable.
Thanks for the input!
Regards,
Roger
Regards,
Roger
Fredonia, NY, USA
Feb 6, 2019 07:04 AM
Joined 5 years ago
John Deere Corn Head Grease AN102562 NLGI "0" grade 14 oz. tubes. Available from your JD dealer in Australia.Also - https://www.agensonline.com/index.php?main_page=product_info&products_id=270015
Nick Cherau
Fredonia, NY
Edited 1 time(s). Last edit at 2019-02-06 07:11 AM by NickC.
Nick Cherau
Fredonia, NY
Sprite1956
Roger Parry-Jones
Feb 6, 2019 07:17 AM
Joined 3 years ago
littlecars
David Bassett
Nashville, TN, USA
Feb 6, 2019 08:02 AM
Amazing stuff. There was a pretty thorough discussion of cornhead grease properties a few years ago on this forum. Guys on the motorcycle forum have also claimed some benefit over "fork oil." Employees at Tractor Supply (doesn't only get used on John Deere, natch
) will look at you funny because it is sold in large volume containers and you will use something like 10 oz of the stuff. Keep the remains for future projects!
padutchmidget
Richard W
Feb 6, 2019 08:55 AM
Joined 3 years ago
Nick,
Thanks for the John Deere corn head grease recommendation! back when I lived on Long Island I would have to buy that off the internet. here in Lancaster County I can pop over to my local Deere Country store and pick some up. We just brought home a new puppy so my front end investigation my be delayed. Thanks to all for all the advice once again.
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
