V8 coil and tachometer feed
Spen Spencer M
Liverpool, Merseyside, UK   GBR
Hi can anyone help on the subject of feeding the b tachometer from the V8 electronic distributor and coil to get the feed to operate it ?
Thanks
Spen
BFC Avatar
BFC Ben Clark
Allegan, MI, USA   USA
1980 MG MGB "Kilr B"
1980 MG MGB MkIV
There's some stuff out there on it. The trick is using an adjustable potentiometer to modulate the inbound pulses.
http://www.britishv8.org/Articles/MGB-to-V8-Tach-Conversion.htm
Tach Wiring Diagram
The potentiometer can be bought from Amazon.
There are a lot of dead links out there, but the above ones work. For more info, google "mgexp.com V8 tachometer" or "mgb V8 tachometer".
I'm not sure if it is in the BritishV8 article above, but one piece of advice I saw somewhere was to wire the potentiometer up so that it was outside the casing of the tach so that you could adjust it as needed.
Finally, I think there are electronic widgets you can buy from Summit or Speedway that are similar to the speedo or fuel gauge widgets that adapt the incoming signal to your tachometer.
Ricey30 Avatar
Ricey30 Phil R
Chessington, Surrey, UK   GBR
Hi Spen
I gave up trying to mod mine with diodes as not that capable
If you google there is a guy in the UK who will adapt it for appx £100
I’ll dig out the link in a moment
Phil
Ricey30 Avatar
Ricey30 Phil R
This guy has good info if you want a go
https://leonsmgb.com/?page_id=761
This is the instrument guy http://www.jdo1.com/
Hope that helps
Phil
Spen Spencer M
Cheers Phil
Spen Spencer M
Cheers Ben
1972 MG MGB GT
