Rover V8 plenum, fuel rail and fuel line ??? Sorted!
Maybe I should put this on the Landy forum but I'll try you guys first. Because parts seem to be NLA the following numbers aren't hot. So using the diagram below do you know what they are/do? 15,16 & 27 - yes the latter's a hose but what's its purpose.
Bottom right of pic2 is the fuel rail nut which has an internal thread but what size/type is it? Doesn't matter as I've replaced it.
The ID of the fuel rail inlet (where that nut is) is 6mm. I want to use Speedflow 200 PTFE for the line but the ID choices are 4.75mm (-04) or 7.95mm (-06). Which ID would you use? Doesn't matter as I need -06 for fuel pump and I'm not going to step it down.
Edited 5 time(s). Last edit at 2019-02-07 01:23 AM by MGB567.
rover plenum1.jpg    34.4 KB
fuelrail.jpg    27.2 KB
mstemp Avatar
mstemp Silver Member Mike Stemp
Calgary, AB, Canada   CAN
15 idle air control valve. GM part is usable.
16 chamber that lets the metered air into the intake for IACV
17 hose bringing air around the butterfly valve into intake so IACV can function.
Simon Austin Avatar
#15 also known as the stepper motor. Used to control idle speed. I swapped this on my RV8 a few times. I purchased it locally. I think I even have an old one around here.
https://www.amazon.ca/ACDelco-217-437-Original-Equipment-Injection/dp/B000C9LBHK
1970 MG MGB MkII
