Need a measurement please - solved
Anyone have at hand the measurement from the back of the valve to the cylinder head face on Rover V8. It's evening as I type so I can't measure until I'm back at the car tomorrow. Dr G doesn't seem to have or if he does he won't give it up. smiling smiley
Edited 1 time(s). Last edit at 2019-02-25 02:07 AM by MGB567.
Walrus1954 Avatar
Walrus1954 Neil Peniston
Calgary, AB, Canada   CAN
Hi Barrie,
I measured the distance from the valve face to the cylinder head face as 7.65 mm. Hopefully that was the distance you were looking for. I have cylinder head on the bench at the moment so I can get any measurement you require.
Cheers Neil.
Thanks Neil but that's not the one and I realise they're probably different depending on the head being used - I just thought someone might have done this so when I do it I know if I'm in the ballpark.
The measurement I was after is called "from the back of the valve" and is actually from the backside of the valve aka valve face as opposed to the valve head so way down on the back of the valve near the piston and then all the way up the valve stem and out to the head's face. You measure the nearside and farside add together and divide by 2 and that gives you the length of the runner from the back of the valve to the head face. Then you add that to the length of the manifold runner (measured in a similar way) add on the thickness of the plenum and any gasket and that gives you the total length of each runner. From that with the help of the cam's specs you can plug it into a program and it'll give you the optimum height to set each trumpet depending on whether you're after HP or torque.
valve.jpg    3.6 KB
Anyone? I'm measuring 4" give or take. If not a Rover I'm assuming any BOP would be the same. I'm just trying to see if I got close with my measuring.
Denis Avatar
Denis Denis Hill
Barrie I cant see how valve length can relate in any way to runner length?? Just wondering. The way we used to check runner length was with a thin sticky tape. Run it along the roof of the runner, making sure it follows the shape, from the valve seat to the mouth. Do the same on the floor of the runner, add together then divide by 2. Your cam design should play a big part in your overall torque/power result. Going larger in diameter with your trumpets has the same effect as cutting them short, but it also means you need more room above them for efficient flow. I would try to keep the length the same but not be concerned about what the length is. You will have heaps of torque anyway with that engine, and soon looking for better gearing.
Denis
Edited 2 time(s). Last edit at 2019-02-23 12:30 AM by Denis.
"The way we used to check runner length was with a thin sticky tape. Run it along the roof of the runner, making sure it follows the shape, from the valve seat to the mouth. Do the same on the floor of the runner, add together then divide by 2."
Denis it's beyond my paygrade to fully understand but it seems the computerised programs work on optimising the runner length for a particular harmonic. The program needs to know the runner length from the back of the valve. Then with the other info as outlined in #3 you can calculate the sweet spot for the height of the trumpets for either HP or torque. I can go back and measure as you suggest which was also what the programmer said but I am able to see the back of the valve where the neck and face meet and I was able to shape a soft wire that went from that spot up the neck and out the head port's centreline. I know I have plenty of room inside the plenum chamber for airflow and while it might seem crazy I figured given the heads have been worked and the roller cam/rockers are in there I might as well see it through to the ultimate.
Denis Avatar
Denis Denis Hill
So what ultimate are you looking for max HP or torque? Remember your "maximum" torque will be around"3500 revs . Your max HP might be in the 6000 rev area, The rest of your engine seems to be setup for HP
Denis
Probably torque but I need to see what the computer program says.
BTW the measurement is 4.5" using the long + short/2 measurement.
FWIW I am now equipped to set the distance from the back of the valve to the top of my trumpets at 12.95" as determined by the computer program. That's according to the 3rd harmonic but as my calculations were done for free I didn't pursue what that really means. Anyway it is what it is now so onwards and upwards.
