Fitting Rover V8
JonPiz Avatar
JonPiz Jon Pizzala
Chelmsford, essex, UK   GBR
Is it best to install the engine and gearbox as one or separately.
1978 MGB GT
Denis Avatar
Denis Denis Hill
As one Denis
Walrus1954 Avatar
Walrus1954 Neil Peniston
Calgary, AB, Canada   CAN
Hi Jon,
Just did it last weekend. Fitted them as a unit. No sweat as long as you can tilt the assembly and lift the rear end of the car. Having a mate to lend a hand is also helpful.
Cheers, Neil.
Me too. But I daresay it depends on which gearbox you have and how you anchored it. As I used the >74.5 gearbox xmember albeit modified to take my T5 mount and the T5 still extended rearwards past the fixed xmember it was easier to install as a unit. To assist with R&R I also modified the slam panel by removing the offset stay that joins the slam panel to lower apron as that stay clashes with my condenser. I also drilled the spot welds either side of the slam panel where it joins the inner guards and repaired/smoothed the area. Next I drilled a pair of holes and welded nuts to the outer inner guard then I made small "wings" for either end of the slam panel to replace the metal ruined by removing it with corresponding holes. Now I have a removable slam panel (which is needed for the bonnet's catch system) and I don't have to have the V8/T5 at such an angle thus easing slippage into my unmodified transmission tunnel.
Ricey30 Avatar
Ricey30 Phil R
Chessington, Surrey, UK   GBR
Hi Jon
Jack the back right up and as long as you have the hoist with the tilt mechanism you can get it in bits a two man job in my opinion
It’s bad enough getting the gearbox lined up and connected it if the car let alone under it
Phil
JonPiz Avatar
JonPiz Jon Pizzala
Thanks for the advice
1978 MGB GT
Simon Austin Avatar
Another vote for installing as one unit. The first photo will give you some idea of the angle required to install. The second is just prior to install.
IMG_4735.JPG    51.3 KB
IMG_4730.JPG    54.5 KB
As I suggested Simon it's not hard to make the slam panel (or the support panel) removable once you unpick the spot welds. And then no need for that angle especially at the gearbox end.
40indianss don foote
2walla wa, USA   USA
Modifying the center crossmember to be removable is another way to simplify this process plus makes removing the transmission easy while leaving the engine in place if repairs are necessary. You can spend the time at the beginning of the project or later when fighting with the entire assembly
DSC00638.JPG    50 KB
DSC00641.JPG    52.7 KB
DSC00642.JPG    33.1 KB
Simon Austin Avatar
To each his own but I have no issues getting that angle to install an engine. As I don't plan to R&R the engine on a regular basis, I'd rather leave my car intact.
+1 Yes No Thank
2walla wa, USA   USA
If a clutch,throw out bearing, etc. needs replacing why remove the engine when only the transmission and driveshaft can be disconnected especially if you have a two or four post lift. Quicker and less mess. None of these cars are left intact by the nature of what we do to them. Running the exhaust through holes in the inner front fenders is not leaving these cars intact as an example. Everyone deals with the challenges in what they perceive to be the best solution
JonPiz Avatar
JonPiz Jon Pizzala
I have another question. As the engine is from a Rover P6 the carb configuration is as per the attached photo. My question is would the airbox in the picture fit as well
1978 MGB GT
51588494_10157048043982566_7206867818887774208_n.jpg    68.3 KB
Simon Austin Avatar
Since the SU’s on the GTV8’s were moved to the rear of the engine bay, my guess is the P6 configuration will have clearance issues in a B.
AC7EC624-4B96-470E-9320-639AC76236B0.jpeg    69.9 KB
