Computer on a Rover 4L
Posted by Drew Ledet
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 6, 2019 10:15 PM
Joined 1 year ago
Hello guys, I was wondering if a computer was necessary for the 1999 4L v8 to run. Thanks
Sunshine Coast, Queensland, Australia
Feb 7, 2019 01:20 AM
![]() ![]() Joined 8 years ago
I would have thought yes for EFI and no for carb but I'm no expert.
Edited 1 time(s). Last edit at 2019-02-07 02:30 AM by MGB567.
allanreeling
ALLAN R
RANDLAY, TELFORD, Shropshire, UK
![]() 1970 MG MGB V8 Conversion
Feb 7, 2019 06:27 AM
Joined 7 months ago
Are you intending to use the injection system? if so, yes!
soonerv8
soonerv8
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 7, 2019 07:06 AM
Joined 1 year ago
allanreeling
ALLAN R
Feb 7, 2019 07:32 AM
Joined 7 months ago
If this is a 4litre which succeeded the interim engine, with a serpentine belt drive it probably has the crank driven oil pump and no distributor drive. Ignition, i think, relied on engine speed sensors and the ECU to control it.
soonerv8
soonerv8
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 11, 2019 06:25 PM
Joined 1 year ago
Sorry for reviving a dead thread but I just read a post on here from around 6 years back that says all I have to do is change the front of the engine and I’ll be able to add a distributer. Thanks for all the help!
trewjohn2001
John Trew
Dorset, Poole, UK
![]() 1969 MG MGB GT
Feb 11, 2019 09:49 PM
Joined 8 years ago
You can still buy new timing covers from TA Performance if you can’t find a good used. You’ll also need the camshaft with distributor drive gear, much more choice on off the shelf cams with the distributor drive camshafts so not a bad thing.
http://forum.britishv8.org/read.php?13,44699
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 12, 2019 06:48 AM
Joined 1 year ago
Do you know what model I have have to use on their website ? I have heard 215 being tossed around, but I doubt that is applicable to my engine, and where would I get one of these distributer drive camshafts? Sorry if I’m being too... questiony, Thanks!
In reply to # 3890115 by trewjohn2001
B-racer
Jeff Schlemmer
Shakopee, MN, USA
Feb 14, 2019 06:43 AM
![]() ![]() Joined 12 years ago
You may find it cheaper/easier to go buy a salvage yard 3.9. Its the same displacement motor, but with a distributor, and the appropriate front cover, cam, oil pump, everything you're going to need.
jeff@advanceddistributors.com
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 14, 2019 06:51 AM
Joined 1 year ago
I actually just pulled the 4L out of a pull a part, do you think they would let me get away with the front cover or would I have to buy the entire engine?
In reply to # 3891363 by B-racer
Not-Anumber
Chris Silk
Southend, East Anglia, UK
Feb 14, 2019 08:15 AM
Joined 4 years ago
Personally i would say that if you already have the 4.0 engine without a distributor there is no reason to think you need to sell it and obtain a 3.9. As an alternative to changing front covers you could go distributor less. A Megajolt or a Nodiz will entirely remove the need to have a distributor, is not very costly and is dead simple to install and adjust. My experience of using them on Pinto engines has been entirely positive.
V8MGBV8
Carl Floyd
Kingsport, TN, USA
Feb 14, 2019 08:46 AM
![]() Joined 14 years ago
In reply to # 3891367 by Drew Ledet
The 4.0 has lighter pistons, longer rods, beefier crank, & cross bolted mains. It is a bit longer, but can be made to fit a B.
http://www.britishv8.org/MG/JimStuart4.htm
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 14, 2019 10:22 AM
Joined 1 year ago
Would this require a computer? I am kind of dead set on not having one installed, not to sound like an ass or anything
In reply to # 3891402 by Not-Anumber
Drew Ledet
Andrew Ledet
Hernando, MS, USA
Feb 14, 2019 11:01 AM
Joined 1 year ago
Dumb question, sorry
In reply to # 3891491 by Drew Ledet
V8MGBV8
Carl Floyd
Kingsport, TN, USA
Feb 14, 2019 11:08 AM
In reply to # 3891528 by Drew Ledet
No, it is not. Sure the path is easier to use a 3.9 with a dizzy, then add a carb. Not as easy, but that is also do-able on the 4.0.
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
