Buick 215 front cover to Rover 4l
Drew Ledet Andrew Ledet
Hernando, MS, USA   USA
Hello, I was wondering if anyone has had any success fitting a Buick 215 front cover to a rover 4l, it seems to be able to bolt on fine but I do not understand how the oil pump connects to the rest of the engine, thanks
mstemp Avatar
mstemp Silver Member Mike Stemp
Calgary, AB, Canada   CAN
You will need a different oil pickup tube, oil pan and a different cam shaft to drive the 215 oil pump.
Thanks for the Reply! Do you have any idea of where I could get these? And shouldn’t the cam be fine so long as I add a distributer drive gear and a distributer? Thanks
mgv8glen Avatar
mgv8glen Gold Member Glenn Towery
Dover, DE, USA   USA
Drew it is all different 3.5, 3.9, 4.2 is old school, camshaft drives the oil pump, 4.0 & 4.6 the crank drives the oil pump. You have to change the cam, a must & you have to use every thing on the front of the early engine & you will need a spacer to go in the harmonic balancer for the nose of the crank is different
I hate to be so... questionitive, but will any old camshaft from a old rover v8 do?
mgv8glen Avatar
Dover, DE, USA   USA
Buick Olds. Rover, All will work
Ok, thanks, I’m looking at a cam from a 3.5 that is carb and efi compatible, from what I’m hearing, that should work right? And should I get some lifters too? Again, I’m very sorry for being so inquisitive, if you couldn’t tell, this is my first time
allanreeling ALLAN R
Is it definitely a 4litre? Land Rover re-named the later 3.9 as 4 just to differentiate it, the capacity was unchanged but several other things changed.
Some have managed to accommodate the crank driven (and better) oil pump, which was fitted to the "interim 3.9" and later 4.
soonerv8
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kingsport, TN, USA   USA
In reply to # 3908938 by Drew Ledet Ok, thanks, I’m looking at a cam from a 3.5 that is carb and efi compatible, from what I’m hearing, that should work right?
Yes, new lifters & new cam.
Why a 3.5 cam. Even a 3.5 will run stronger with a 3.9 cam. Find a decent performace cam,
Are you putting this engine In an MGB? If so, why use a truck cam. Get a sports car cam. winking smiley
It is a 3.9, they just called it 4l, which you already know
I don’t know, I wasn’t aware that anything other than a rover disco can would work, can any cam work with any engine? And if so, does it have to be specifically dizzy drive?
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
In reply to # 3909145 by Drew Ledet It is a 3.9, they just called it 4l, which you already know
They called the new 3.9, a 4.0 (1998-2002) because internally it is not the same. It has different crank, rods, pistons, etc.
http://www.gomog.com/allmorgan/40difference.htm
