MG Performance Forum
Manifold Vac Advance vs Ported on the street
GeorgeOhr Nonya Business
Yes, confused, USA   USA
For guys like me with DCOEs, is it possible to run manifold vac advance on the street? I've read conflicting things over the year. I'd especially like to here what Jeff has to say.
No
Berwick, NS, Canada   CAN
In reply to # 3660846 by GeorgeOhr For guys like me with DCOEs, is it possible to run manifold vac advance on the street? I've read conflicting things over the year. I'd especially like to here what Jeff has to say.
You must have a manifold... with vacuum in it. What would the stumbling block be?
Adrian
The stumbling block is the dcoe
Ported or manifold the vacuum signal is erratic
That's the reason you cant run vacuum advance with a dcoe on an mg
In reply to # 3661047 by ohlord The stumbling block is the dcoe
Why is the signal erratic?
Adrian
Alternating intake pulses
Unstable signal
Balance tube.
Adrian
Been tried
The balsnce tube doesnt balance the vacuum signal
Common knowledge when running the sidedraft DCOE and the reason you need to run it with a mechanical advance only distributor.
Interesting. The engine has the same "intake pulses"(unless I'm missing something) with twin SU's in place and it isn't an issue. Do you have any idea why the Weber doesn't react the same way? In plan form it looks like 2 tubes with butterfly valves just like 2 SU's. Or does "it just does" satisfy everyone?
Adrian
Dual su has vacuum from one carb only or manifold
The dcoe has alternating vacuum pulses even if you used the balance tube.
and ported from just one barrel
Is worse
converse212 Avatar
converse212 Eric Morgan
Tucker, GA, USA   USA
1958 MG MGA
1970 MG MGB "Daily Driver"
1970 MG MGB GT "Rusty"
1971 MG MGB GT    & more
couldn’t a small reservoir be used to smooth out the vacuum signal some? It seems like a film canister sized container and pulling vacuum from both runners would produce a reasonably smooth signal...
I guess the way to test this would be to hook a vacuum gauge up to both runners and look at the needle under running conditions.
Rob, don’t you run a dcoe?
Daily driving a '71 MGB
Resurrecting a '58 MGA
I failed to specify single DCOE.
In reply to # 3661216 by ohlord Dual su has vacuum from one carb only or manifold
Is worse
I'm seriously intrigued by this. How does the Weber do this while dual SU's do not? (manifold vacuum)
Adrian
Look at the manifold designs
converse212 Avatar
Tucker, GA, USA   USA
1958 MG MGA
In reply to # 3661315 by ohlord Look at the manifold designs
What’s the difference? Lacking a balance tube on the dcoe manifold? Well sure, so pull from both runners.
Otherwise, what’s the difference?
