Rich McKie
Steveston, B.C., Canada
Posted: April 16, 2012 06:51PM Registered: 6 years ago Posts: 5,387 |
I now have 7 spare stock length pins which I hope to never use. I was able to do some minor repairs on the less badly damaged housings using super glue.
)along with their mounting bolts. As long as you are removing the shocks you may want to install braided brake lines as they mount along with the shocks at the front. Don't forget...You WILL need a way to pump up your Hydragas suspension when you are finished, so if you don't have your own pump you will want to check with your local British car repair shop to see if they have one you can rent/borrow. A good fluid mix is 50% Glycol Antifreeze/ 50% methyl alcohol.(which is commonly used in marine stoves).
John Stevenson
Paradise, Paradise, near Octagon Pond!!!(Yes, really!!!), Canada
Posted: April 16, 2012 08:26PM Registered: 3 years ago Posts: 567 |
Rich McKie
Posted: April 16, 2012 08:43PM Registered: 6 years ago Posts: 5,387 |
Posted: April 17, 2012 06:25AM Registered: 13 years ago Posts: 3,131 |
Posted: April 17, 2012 06:26AM Registered: 8 years ago Posts: 834 |
John Stevenson
Posted: April 17, 2012 07:15AM Registered: 3 years ago Posts: 567 |
Rich McKie
Posted: April 17, 2012 10:50AM Registered: 6 years ago Posts: 5,387 |
Rich McKie
Posted: April 17, 2012 10:57AM Registered: 6 years ago Posts: 5,387 |
MGB & GT · MG Midget · Buy, Sell & Trade · Vendor & Group Buy · MG Engine Swaps · Original MG · MGA · MGC · MG Magnette · 1100 & 1300 · T-Series & Prewar · Modern MGs · MG Motorsports · MG-2013 Event · Member Meetup · Other Vehicles · Off Topic · Clubs
→ mgexp.mobi
More websites in the AutoShrine Network:
You can Login with the same Member ID on any website in the AutoShrine Network
© F4 Systems unless noted - ASN/CMS v5.7 - Terms & Conditions - G+ Page - Problem or suggestion? Email the webmaster ![]()
