Modern MGs Forum
But is it a real MG?
Posted by princess-cyanide
philip may
hampshire, United Kingdom   gbr
Some time ago (just after Rover went TU) I bought a 3 bearing 1800 b series engine from an unemployed development engineer from Longbridge. We chewed the cud about MG's of course. He was desperately disapointed with the MGF as it was starved of development, The replacement was nicked by BMW and became the Z4! or so he claimed!
Rich in Vancouver Avatar
Rich McKie
Steveston, B.C., Canada   can
1996 MG F "Andy" ~ For Sale ! ~
1997 MG F "VVC"
Not quite, but BMW did put the kibosh on the MGF Supersports.(Supercharged, flared out, competition suspension MGF)
One of the BMW directors visited Longbridge shortly before the Z4 was released and drove the Supersports prototype.
After he left the car was pushed to the back of the factory and covered with a dropsheet. Apparently it went very
well and was at the same price point as the Z4, so bye-bye Supersports!
Modern MGs aren't just Transportation, They're a Hobby!
ron neal Avatar
South Carolina, USA   usa
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC
1969 MG MGC GT   → more
I wonder what happened to the MGF Supersports?
Ron
Rich McKie
1997 MG F "VVC"
The prototype is still out there, owned by an enthusiast in the UK, and is in
regular use. I wish someone would take a set of moulds off the wings and bumpers.
They make the car look much more aggressive but I sure wouldn't put them
on my car unless it had the power to back up the look!
Here's a pic of the car in 2009. Apparently before it was sold off the supercharged engine was removed.
The current owner has built up a turbocharged engine that apparently puts out 232hp.
Bet it goes pretty good!
Sort of what the 930 Turbo was to the Porsche 911 innit!grinning smiley
This is the current engine.
Edited 2 time(s). Last edit at 04/01/2012 01:59PM by Rich in Vancouver.
Simon Austin Avatar
Surrey, BC, Canada   can
How does these number compare to the SC engine, Rich? I could look it up but might as well chat about it.
Rich McKie
1997 MG F "VVC"
In reply to # 2028521 by Simon Austin How does these number compare to the SC engine, Rich? I could look it up but might as well chat about it.
I really don't recall what the HP (KW?) was on the supercharged engine. I don't think it was quite that high. 210HP rings a bell.
A turbo'd engine is a totally different beast though. It must be a very exciting car to drive. At least it has the wider wheels and
the suspension mods (Apparently the same as the MGF Cup cars) to handle the extra power.
If I was in his position I think I would go with a supercharger as they are generally more tractable and generate less heat, which would be an issue in an MGF. You could mount it in the same position as his turbo and route the intake pipe around the head to the intake manifold. I'm sure that there is an appropriate Eaton blower available, after all Moss do one for the B-Series 1800 and Jackson racing have a Miata kit, or there is always the Swedish blower that the Aussies use in the MGB. It would be a matter of an engine rebuild with lower compression pistons, and a blueprint and balance would be a good idea. If you were running a VVC engine solid cams would probably be called for.
In my fantasy world I do play with visions of an MGF with the KV6 V6 (I know John!)with a blower. That would be a challenging conversion!
terreneuve Avatar
John Stevenson
Paradise, Paradise, near Octagon Pond!!!(Yes, really!!!), Canada   can
1952 MG TD
1967 MG MGB GT
1968 MG MGC
1986 Land Rover Defender 110
1995 MG F   → more
In reply to # 2028531 by Rich in Vancouver
A 2.0 Turbo like the one in my Rover Tomcat could be tweaked and used instead of a KV6 to get you a good result!!
Rich McKie
1997 MG F "VVC"
In reply to # 2028578 by terreneuve
There is a fellow in the UK working on a T16 conversion. Apparently the engine only works out to 26 kilos heavier than the K-series.
A 2 litre turbo would be fun. Does the Tomcat use the PG1 gearbox?
terreneuve Avatar
John Stevenson
1952 MG TD
1967 MG MGB GT
1968 MG MGC
1995 MG F   → more
In reply to # 2028629 by Rich in Vancouver
Yes, it apparently is a PG1, and you can pick up an engine in the UK pretty cheap!!
Rich McKie
1997 MG F "VVC"
In reply to # 2028649 by terreneuve
Like every other big heavy part the catch is getting it here.sad smiley
It would probably be cheaper to buy a car in Japan, salvage what is needed, scrap the rest and turn the ID plates in to the authorities
I have often thought it would be worthwhile to buy an MGF in Japan with HGF, import it and strip it for parts.
philip may
I remember the Supersport, I saw it race at Prescott (I think) hill climb. It was also at Gaydon Motor museum I think.
The meeting I had was a few years after that. The engineer described the car as having front engine rwd layout, M3 6 cylinder engine and hydrolastic suspension. All very diferent to the MGF SS
richard flasck
toledo ohio, USA   usa
Why is no one discussing the MG TF Victor.Built in the 80's - identical body to the '55 TF with an MGB engine trans. Etc.Excellent tubular frame suspension, etc. Mostly fibreglas,but looks like the real thing,and drives much better.RAF
Simon Austin Avatar
We are now, Richard. smiling smiley I've looked at the thread on the MGB forum. Good looking cars.
ron neal Avatar
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC
My buddy has serial number one. How many did they sell before going TU. Another friend bought it in SC close to Shaw AF base, the used car dealer thougt it was real and we had to explain that it was a kit car, he finally sold it to us cause nobody wanted it. LIke when they were new.smileys with beer
It really is a nice car.
Ron
Rich McKie
1997 MG F "VVC"
There have been a few decent MG look-alike kit cars made over the last couple of decades, and a lot of terrible ones, mostly before that, but no matter how many MG badges they have on them they are not MGs. The first thing I look for when I see a T-Series MG driving down the road is look at the exhaust. If it's a VW exhaust I look no further.
The fact that Victors and NGTCs used MG engines doesn't change the fact that they are kit cars even though they may have been built to very high standards.
One interesting sidebar to this is MG "Specials" These are cars that are built from MG parts, either singly by their owners or in very small quantities by specialists and are accepted by the MG community for what they are. They don't ape existing MGs and aren't meant to fool the unitiated into thinking they are MGs, but have their own individual (sometimes Very individual!) identities.
Of course this brings us to the MGB-GT 50th anniversary edition, 50 of which are being built by Costello Frontline in Abingdon England. MG or not? Special or not?grinning smiley
terreneuve Avatar
John Stevenson
1952 MG TD
1967 MG MGB GT
1968 MG MGC
1995 MG F   → more
In reply to # 2029422 by Rich in Vancouver There have been a few decent MG look-alike kit cars made over the last couple of decades, and a lot of terrible ones, mostly before that, but no matter how many MG badges they have on them they are not MGs. The first thing I look for when I see a T-Series MG driving down the road is look at the exhaust. If it's a VW exhaust I look no further.
I looked at the Frontline 50 when I went to the NEC in November and it is quite well done, but for the price would I buy one....NO!!
Realistically though, you would pay the same amount to have a GT restored by someone else so for some people it makes sense. Is it a real MG? In body only, not soul!!
ron neal Avatar
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC
John
I agree, it is a MG in body only, not soul. Have not seen one in person but from what I read it is well done. Of course for that kind of money it should be.
Did you drive my car when it was at Luffields, Longbridge or in Florida?
Ron
terreneuve Avatar
John Stevenson
1952 MG TD
1967 MG MGB GT
1968 MG MGC
1995 MG F   → more
In reply to # 2029871 by ron neal John
Ron
Hi Ron,
At Wirewheel, they also had a blue ZS there at the time but I don't know where that one went!
John
Mark Jones Avatar
SW, Ontario, Canada   can
1970 Triumph Spitfire MkIII
1995 MG F "Barney"
Okay, I've said that the SV isn't my thing, but I'd still love to take it out for a drive. "John, you're despicable." (said in my best Daffy Duck voice).
Canadian Modern MG Rover Car Club - www.cmmgrcc.org
terreneuve Avatar
John Stevenson
1952 MG TD
1967 MG MGB GT
1968 MG MGC
1995 MG F   → more
In reply to # 2030029 by Mark Jones Okay, I've said that the SV isn't my thing, but I'd still love to take it out for a drive. "John, you're despicable." (said in my best Daffy Duck voice).
Just to show how despicable I am, I was lucky enough to drive Ron's car and an SVR that Wyles Hardy had for sale in Hemel Hempstead!
I should be shot!!!!
