MGC Forum
Carb spits back
Jimenez Avatar
Jimenez James Elliott
BellsHill, Scotland, UK   GBR
1968 MG MGC
1968 MG MGC
Hi everyone
Can anyone help and tell me what would cause the carbs to spit back
I have checked the timing,and all the electrics the carbs seem to be getting fuel alright
It is very hard to start when cold but when it does start it sounds and runs great
This only seems to have happened after I rebuilt the top half of the engine
HELP !!!!!!!!!!
emadak Avatar
emadak Gold Member Ed 123Ignitionusa LLC
Columbia Station, OH, USA   USA
1969 MG MGC
Carbs too lean
Regards
Ed
Amgcr#1419
Http://123ignitionusa.com/
US Supplier of 123Ignitions, Pre-programmed\switched models, Programable PC models and "NEW" Wireless Bluetooth models for Apple or Android. Search (123\Tune+) For perfect timing.
Jimenez Avatar
1968 MG MGC
1968 MG MGC
Thanks Ed
I will give them ago tommorrow
Cheers Jim
Tim Moore Avatar
Scotland, UK   GBR
1947 Rover 16 "Reggie"
1969 MG MGC GT
Take it that you've rebuilt the carbs, new jets etc? Agree that it could be too lean. Workshop manual from SU is pretty good detail on how to get this right. If ypu have trouble starting from cold presumably with choke out settings/balancing seems the issue,
Mowog6 Patrick Cheffins
Auckland, New Zealand   NZL
1969 MG MGC
Also worth checking for other causes of a lean condition, i.e. air leaks, such as:
-any gaskets missing on carbs (both sides of plastic insulator)
-any bolts loose in the path from head to carb body
-servo or servo vacuum line leaks
-leak from distributor vacuum advance pipe (though this is v. unlikely to cause backfire)
Patrick
Swamperca Avatar
Swamperca Swamper CA
-, Nor Cal, USA   USA
1969 MG MGC GT "C-Rod"
1971 MG MGB "Rubee"
1974 MG MGB "Groovy B"
Brake vacuum line leak also.
Al ain, Abu Dhabi, United Arab Emirates   ARE
Too lean was my thought, causing slow fuel burn and backfire.
Jimenez Avatar
1968 MG MGC
1968 MG MGC
Thanks Guys
The front carb was running a bit lean,
roaring like a lion again and driving a dream,
just need to align the lights and give it a good clean .
Regards Jim
emadak Avatar
1969 MG MGC
Great! Glad to help. Enjoy the ride.....
Regards
Ed
Amgcr#1419
