MGC Forum
Front brakes . . .
Posted by RogWarham
Roger W
Leamington Spa, United Kingdom   gbr
It appears I have a slightly warped drivers side brake disc. Will need to replace it - so will replace both sides at the same time. Any preferences as to type to fit, as I would like to improve the stopping ability a little!
Dont what the expense of changing the calipers really if I can avoid it.
Any pointers?
Regards
Roger
kobym Avatar
Koby Millo
Tel-Aviv, Israel   isr
1969 MG MGC
If your discs are thick enough, you don't need to replace them - they can be turn on a lathe and made straight again.
Anyhow, unless you go for slotted disks, I believe that a bigger advantage for stopping power could be gained by installing high quality pads.
Reg.
Koby
chormy Avatar
Shaun Holmes
Norwich, Norfolk, United Kingdom   gbr
1963 MG MGB MkI "3330 PE"
1968 MG MGC "Crosby"
1969 MG MGC GTS "Yippee"
2005 Land Rover Range Rover
EBC green or yellow pads depends on your driving style, you can upgrade disc to the EBC slotted n dippled discs prob cost £230
mgcgt2912 Avatar
Richard Bailey
Cully, East Devon England, United Kingdom   gbr
No argument with Koby.
But discs are not expensive to buy new. How much is a engineering shop going to charge you to skim them ?
Roger/ By the use of an exclamation mark, it would seem you dont like the brakes on your car. I suggest therefore that they aren't working properly.
IMHO standard discs and calipers, in good condition, stop these cars very well for normal road use.
R
Roger W
As the car is a new acquisition to me, I have just had it given a complete check over and service, which is where they picked up the warp disc (it was one of the things on my list for them to checkout in detail - you can feel it at low speed braking, so its not way way out, but it does show on the test rollers.)
Was due to have a set of EBC Greens put on while it was in there, but thats on hold in light of the warp disc. May as well go for the EBC discs so it all matches up.
Brakes are all working fine - its me coming from a 500kg Caterham with 4 pots on is the reason for the exclamation mark!
Rog
kobym Avatar
Koby Millo
1969 MG MGC
In reply to # 2105589 by mgcgt2912 No argument with Koby.
Just to explain - in Israel I have no chance to buy locally discs for an MGC... So, they have to be imported, which means shipment costs and customs.
On the other hand, we have here many small shops which specialize in disc turning, for a relatively modest price. Therefore, it was a very good approach for me. Might not be the same in the UK where discs are easily found, and labor cost is high...
Reg.
Koby
ron neal Avatar
South Carolina, USA   usa
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC
1969 MG MGC GT   → more
Roger
I agree with Koby and would try to turn them first. Yea I will bet after driving a Caterham the MGC seems to stop like a log truck. LOL
ROn
Big6Mark Avatar
Mark Miller
Springfield, OR, USA   usa
1960 Austin-Healey 3000
1968 MG MGC "Red Tail"
1968 MG MGC
1968 MG MGC GT "The Wreck"
1969 MG MGC GT "The Lump"
Personally I only like new, full thickness rotors. With a non-directional finish and new pads.
If your rotors are warped it is because they have been subjected to excessive heat and trueing them up will only help part way. In addition, your hubs may be warped as well.
Take the hubs off the car and have the mounting face of the hubs checked for true and if not there will be no reason to fit new rotors until these are fixed or replaced. Then you can fit new rotors and they will be true as well.
Then take the car out and burnish the pads properly (used to be called "bedding the pads"winking smiley and then the MGC will brake quite well.
Sure, a lot of improvement can also be gained by improving the suspension and tires to get a better grip on the road. Properly done an MGC will almost stand on it's nose on the brakes! Have nearly collected quite a few other cars in the boot of my GT.
And I think the problem might be that the Caterham is missing a few parts to make it heavy enough to stop like the MGC as well.
C Ya,
Mark
spikemichael Avatar
Michael Caputo
Athol, MA, USA   usa
1973 MG MGB "Freebie"
1976 MG MGB "B-4"
1979 MG MGB "MegaBeanie"
1989 Suzuki Intruder 800   → more
Contact forestghost07 in the MGB forum... Marco Sinai is his name. Tell him I sent you. He picked up drilled and slotted discs recently and went on and on about the improvement in stopping power. As i recall they were quite reasonably priced.
Michael J. Caputo
MG CALENDARS! MGB or MGA order TODAY!   – Athol, MA USA $20 delivered anywhere! Visit www.mgbcalendar.com or CALL 617-674-4367
Roger W
Just thought I would update on this.
Hubs all check and are fine and true. Have fitted EBC slotted and dimpled rotors and Green Stuff pads along with a set of Aeroquip braided hoses. Pads bedded in carefully . . .
I think the braided hoses have given a better pedal feel too - well worth doing.
Rog
