MGC Forum
Gear issue in transmission
Posted by hhj1397
hhj1397 Avatar
Hans Jensen
Philly, PA, USA   usa
1969 MG MGC
So...I opened up the access plate on the transmission to take a look. Unfortunately, though everything seemed ok, I noticed a tooth missing from what I believe is third gear. Now, excuse my lack of knowledge here, but it seems like it is the taller, thin gear, not the non synched drive gear. Is this perilous? Or something that can be ignored for now. A transmission rebuild is a bit cost prohibitive a the moment unless dire...
Thoughts?
mgcgt2912 Avatar
Richard Bailey
Cully, East Devon England, United Kingdom   gbr
Gearboxes, I know very little about. Except when they go wrong.. then I ask someone else to fix it or buy a new one.
Having got as far as having the engine and gearbox out of the car, I don't think I could even consider putting it back in with a known problem in the g/box. It has to be false economy.
Unless of course you love the idea of lifting out that great lump again sometime soon !
Just my two pence worth.
R
robert kirk
A pic of the problem would curry more informed advice. IMHO if 2/3 remains and more importantly the missing bit is salvaged/scavenged/removed, an "aware" owner/driver would understand the inferred next foot fall and be somewhat cautious in 3rd gear. OTOH, I do not dispute Richards better advice budget consideration not with standing, his is the more proper avenue to follow.
So we now believe not only was the PO a bit ham fisted, he likewise was challenged with his foot hand co ordination...
I hope it is not so, but it almost appears this is the tip of an iceberg. GOOD LUCK! smileys with beer
Regards,
Robert Kirk
kirkbrit@yahoo.com
563 323 1017
Moss distributor UK importer
hhj1397 Avatar
Hans Jensen
Philly, PA, USA   usa
1969 MG MGC
Watching Jon Twist's video of the details on how the gearbox works, I can clarify a bit. Its a single tooth on the engagement teeth. Its totally sheared off. With the synchro system, I would think since it works on a spline capacity, it would have little effect?? I'm not even sure how that could happen unless it was a defect from the beginning. I looked all around and didn't see any remnants so I am guessing it was an old injury.
I will try to crack it back open to get a picture
bowtech Avatar
Stan Bowles
North Vancouver, Canada   can
1968 MG MGB GT
1968 MG MGC GT
1968 MG MGC GTS
1969 MG MGC GT
2000 BMW 323i   → more
I wonder where the piece has gone?eye popping smiley
hhj1397 Avatar
Hans Jensen
Philly, PA, USA   usa
1969 MG MGC
I'm sure it dropped to the bottom and drained out with transmission oil changes over the years...I looked all over and saw nothing.
Swamperca Avatar
Swamper CA
Nor Cal, USA   usa
1969 MG MGB GT "Rat"
1969 MG MGC GT "A 69 MGC"
1970 MG MGB GT "Widow"
1971 MG MGB "Ruby"
1974 MG MGB "Groovy B"
It could get into the OD.
hhj1397 Avatar
Hans Jensen
Philly, PA, USA   usa
1969 MG MGC
Heres what I am looking at. Note: yes that was ATF in there I believe...will be replaced with 20W50.
Thanks for the advice all!
bowtech Avatar
Stan Bowles
1968 MG MGB GT
1968 MG MGC GT
1968 MG MGC GTS
1969 MG MGC GT
Fairy took it?!!!eye rolling smiley
stephen curtis
berkshire, United Kingdom   gbr
is the car a driver have you changed gears at high speed and revs..
hhj1397 Avatar
Hans Jensen
Philly, PA, USA   usa
1969 MG MGC
It was sitting for a while. I had it up on stands, engine running and shifted though gears with no issue but with no real load.
stephen curtis
just double declutch on change down and up ,if you are not going to remove it
stephen curtis
you will also probealy find it jumps out of gear i also meant to add
hhj1397 Avatar
Hans Jensen
Philly, PA, USA   usa
1969 MG MGC
Thanks for all the help...I may throw it back in and see if there are issues. The engineer in me has a hard time seeing how in a spline connection a single missing tooth out of 30 or so would drastically stress the gear or fail to transmit torque. Good advice with caution and a careful search for the remnants. My guess is this was an old injury that the PO never detected.
stephen curtis
you have the best gear set fitted i noticed ..
