MGC Forum
Will MGC disc brakes fit an MGB or MGA
msd2x lee bogal
Nassau County, New York, USA   USA
Good morning all.
I usually post on the MGA or MGB sites, but I need a quick answer about MGC disc brakes from you knowledgeable MGC folks.
Last week I noticed the carcass of an MGC sitting way back in the weeds of a locak junkyard. I was interested in the MGC for the larger disc brakes and 72 spoke 15" wire wheels for my MGA which has the updated MGB calipers.
I want to know if the MGC disc brakes will fit on a "B", are the MGC calipers the same as those on big Healeys and TR6, and is there a noticeable
increase in stopping power with the "C" disc brakes installed on a "A" or a "B".
Thank you all in advance.
Regards, lee
mowog1 Avatar
Saint Joseph, Illinois, USA   USA
1969 MG MGC "Vicky"
1972 MG MGB "Mallard"
What else is on that carcass?!
mowog1@aol.com
msd2x lee bogal
Rick-
well, "How" Big Chief Mowog.
I've seen your tribal name for many years, usually upside down on MG trannys when i'm under the car crawling around on my back trying to undo the tranny mount bolts-never thought there were any living tribal members, kind of like the mohegans.
tell me what you are looking for and i'll go thru the weeds again and see if such part is there. i know there is no rear end, no hood, and it's been sitting in the weeds exposed to the elements for at least 10 years.
and now that i've done my part for you, if you happen to know, can you let me know:
-are the MGC front disc brakes the same as big Healeys and TR6s ?
-will the MGC front disc brake assemblies fit on on an MGA/MGB ?
-is there a noticeable difference in stopping power once the "C" disc brakes are fitted to an "A" or "B" ?
May your wigwam be filled with the happiness of abundant MG parts.
regards, lee
Davenport, Iowa, USA   USA
msd2x Wrote:
Quote: -are the MGC front disc brakes the same as big Healeys and TR6s ?
Yes with the caveat they are either 16P or 16PB and not 16PB metric as per later TR6.
Anything can be done...for a price or with time or both.
Probably and especially if you also installed the MGC twin servos.
Might consider installing a servo first to "test" how well IT does. I have a smaller 4 cyl version of my PBR servo which would work on a single line brake master or two if you have a dual set up. These are remote style servos as found on MGC and Tiger and later AHealeys.
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
cell 563 940 1864
http://kirks-auto.com/
Moss distributor/UK importer
msd2x lee bogal
Robert Kirk-
Thanks for the info and have a reat weekend.
regads, lee
trymes Avatar
trymes Gold Member Tom Rymes
Concord, NH, USA   USA
Lee,
What, exactly, is your goal here? Street driving? Track driving? Something else?
Larger discs & calipers from an MGC might be worth a shot for track use, but a booster fitted to provide power brakes, as mentioned above, might be a better choice if your goal is reduced pedal force required for street driving.
I doubt that fitting the MGC brakes will provide any significant benefit over MGB brakes for street driving, because the biggest problem you'll have is keeping the wheels from locking up, especially on an MGA!
So, what's your goal?
Tom
All of my weekends are 'reat except when it rains and then they are wet.
As for your A. I kinda like your idea but I think you may be taking on a lot when a servo and ceramic pads would get you there with ease. Either one would be an good upgrade AND keep the components OEM.
An MGB swap is much easier and you benefit from cheaper B parts. Not so with the C. I think you may have to go all the way with a spindle transplant inorder to achieve what you want. While the A and B are quite similar the C is totally designed for that car.
Send me a PM is you need any A B C or LBC parts...its what I do.
Regards,
Robert Kirk
kirkbrit@yahoo.com
cell 563 940 1864
ron neal Avatar
Coastal, South Carolina, USA   USA
Lee
I like your thoughts but feel trying to transplant a set of C brakes on an A or B would be difficult at the least. There are no interchangable parts to speak of as you will need the C spindle which is a torsion bar susp. etc. I dont think the discs from a C will bolt on a B hub either.
Probably better off upgrading your current A or B set up with available parts, orig or after market.
Now the calipers are the same as the AH3000, so are available. MGC uses a Girling setup where a A or B uses a Lockheed one.
As far as stopping power, dont know as I have never heard of someone doing this particular conversion, most just go out and buy a new set of upgraded calipers and associated parts.
Cheers Ron
Edited 1 time(s). Last edit at 2009-07-05 06:38 PM by ron neal.
bills Avatar
bills Bill Spohn
No.
And not worth the bother anyway as several have pointed out.
The MGB calipers that you already have are adequate for anything you can throw at it. I converted to those calipers on my TVR race car, which originally used the Austin Healey Girlings, but in a pad pattern that wasn't easily available in competition compounds (tons of pad choices for MGBs). I threw more at that car on the track than anyone in their right mind on the street would EVER get near and it never faded.
Too many people keep wanting to upgrade what doesn't need upgradingm, while neglecting things that would be useful improvements.
2007 BMW Z4M coupe (340 bhp)
North Vancouver BC
bills Wrote:
Quote: Too many people keep wanting to upgrade what doesn't need upgradingm, while neglecting things that would be useful improvements.
PROFOUND sage advice...a veritable plethora nigh to a myriad of wisdom....
FWIW
Regards,
Robert Kirk
kirkbrit@yahoo.com
cell 563 940 1864
bills Avatar
bills Bill Spohn
kirks-auto Wrote:
Quote: PROFOUND sage advice...a veritable plethora nigh to a myriad of wisdom....
FWIW
Har har!
North Vancouver BC
rocket ralphie Avatar
rocket ralphie ralph zbarsky
Vancouver, BC, Canada   CAN
Sort of like a 5 main twincam engine, Bill?
bills Avatar
bills Bill Spohn
rocket ralphie Wrote:
Quote: Sort of like a 5 main twincam engine, Bill?
I have it on good authority that that has never been done, Ralph... ;-)~
(Besides, some things are too much fun not to try.)
The brakes on the MGC are too far away from MGB to bother trying to use them, although the thicker discs they used on the MGB V8 can be bolted on, as can Austin Princess calipers, if you really want to.
North Vancouver BC
