Off Topic Forum
..Super Anti Spyware??
Posted by wyatt
wyatt Avatar
Wyatt W
penguin point, drift ice, Antarctica   ata
...I run it about twice a week, it used to take appx 1 hour, now the last couple of times it has taken 12 15 hours, and it still is not finished so I shut it down,it is running right now....what gives?? is it corrupted. I do run the updates too....any ideas. it is the free edition.
Wray Avatar
Wray Lemke
., South Carolina, USA   usa
How much stuff have you been accumulating on your hard drive? The reason it takes longer is its looking through more files. Do you ever clear your temporary internet file cache? If not, go to Cnet and download Ccleaner. It is a great utility that clears out old temporary internet files from the computer. Does a better job than Windows.
The SASW can be set to just look through Windows files and registry and leave the other areas alone. That will save a lot of time on the scan.
But first, go get Ccleaner and clean up the temporary internet files. That will take a lot of useless crap off the computer.
Speedy1 Avatar
John Gonzales-Lusk
Los Lunas, NM, USA   usa
Are you sure it's just the computer that's corrupted?
wyatt Avatar
Wyatt W
24 hours and still counting...and yup used Ccleaner and disk defrag and deleted temp and dumped recycle bin and even washed behind my ears...
refisk Avatar
Rick Fisk
In reply to # 2111580 by wyatt 24 hours and still counting...and yup used Ccleaner and disk defrag and deleted temp and dumped recycle bin and even washed behind my ears...
Ya need to stop going to them porn sites Wyatt. thumbs up smiley
bob fuller
crystal lake illinois, USA   usa
You only need to check your "C" drive. If you have large picture files on "C" it will take forever. Dump your large files onto a separate hard drive and don' t let SASW check it. Probably doesn't need checking anyway.
wyatt Avatar
Wyatt W
In reply to # 2111597 by refisk
..Haa I wish that were it, it happened right after my internet provider changed our email,and while the teck was helping me with that I mentioned that my firefox was anoying me with the "update" crap, so after 45 minutes of helping me load all kinds of "important" stuff SAS has not worked right...should I uninstall it and start over?? as far as C drive and photos,and a seperate hard drive....I will need the Higgs Boson perfessers ta help...
DaSpyda Avatar
Don Alexander
Lakeland, FL, USA   usa
I would uninstall, download a fresh version, install and update - then run again. It doesn't delete any data and will take no time at all.
Be careful with CCleaner: if you delete files in Applications/Programs, it can delete your registry files for Office.
If you still have issues, download and install Megabyte's Antimalware - also free at download.com. Heavy duty and easy to use.
It is ALWAYS a good idea to save your important stuff to an external source.
Use Google Cloud for free, or you can buy an external hard drive at Office Depot or Staples. They backup automatically, and show up on your computer as a separate drive labeled like the others - C, D, E, etc. All you have to do is click on any folder that contains your important stuff and drag it to the new drive's folder. I can't tell you how many times I've had to replace or reformat hard drives and irreplaceable pics were on them - especially now that most people have digital cameras.
Don
1970 MGB
2000 MR2 Spyder
JackMG Avatar
Jack Lindler
Greenville,SC, USA   usa
Best free anti-spyware/anti-malware on the market:
anti spyware.jpg (12.6 KB) –
Wray Avatar
Wray Lemke
Wyatt, run the program, go to the "scan your computer".
You can uncheck everything but the C drive and do a "Perform Quick Scan" on it. That should not take a long time.
or:
Check the "perform custom scan", check the "selected folders", click "select folders",a new window pops up, click "add", open "my computer", open "C", go down to the Windows folder and click it, then "ok", the "close" the window, then "next". It will take off and scan the Windows folder, the registry, etc. and should not take long.
I agree with the others; it's checking large files that don't need checking.
I just ran it on my computer, which has a lot of stuff, it took about 27 minutes.
Edited 1 time(s). Last edit at 07/05/2012 11:20AM by Wray.
wyatt Avatar
Wyatt W
...thanks for the help guys, if it all works out, I plan on taking my computer water skiing this week end...
LittleBritishCar Avatar
Rick Anderson
Napa, California, USA   usa
1966 MG 1100 "Julia"
1975 MG MGB "Chiquita"
A lot of the "free" anti-spyware downloads you find on line actually installs spyware and opens a porthole for much more.
DaSpyda Avatar
Don Alexander
That's true... download.com is run by CNET, a trusted source in Geekdom.
Also, if you see the same advice in different sources - Time, CNN, local paper - it's usually an indicator of validation from the tech community.
Don
1970 MGB
2000 MR2 Spyder
Wray Avatar
Wray Lemke
Cnet is the site I use for anything like that. You can trust their reviews.
GILMGA Avatar
Gil Dupre
Chattanooga, TN, USA   usa
1962 MG MGA
1974 MG MGB GT
do www.dns-ok.us to check if you are clean of malware. I use AVG free virus and spyware
Gil
Edited 1 time(s). Last edit at 07/08/2012 01:09PM by GILMGA.
Simon Avatar
Simon Clowes
Salem , Oregon, USA   usa
1979 MG MGB "Big Red"
In reply to # 2111638 by bobobud You only need to check your "C" drive. If you have large picture files on "C" it will take forever. Dump your large files onto a separate hard drive and don' t let SASW check it. Probably doesn't need checking anyway.
Actually Bob, to be "safe" eveery drive needs to be checked. Funnily enough a large number of spyware and virus are imbedded in pictures. I even had an issue (some years vack) where a Photo CD created by a chain photography store ended up with viruses in picturesa created from a roll of 35mm film I had them develope. It cost them big in compensation as something like 400 custoemr were affected.
1979 Roadster (Big Red) daily driver.
unknown GT somewhere in the future.
09 Accent
Don't got to bed made - stay up all night plotting revenge
Wray Avatar
Wray Lemke
Simon, I would have never believed it until I got one. An email from a scammer had a pic embedded in it, which was unusual as it wasn't an attachment, it was so humorous that I clicked on the pic. Wrong. Took me most of the day to get it cleaned out.
It was the only time I've ever encountered a bug like that.
Dan burnett
puyallup, USA   usa
S.A.S. IS A VIRUS!!!!!!!!!!!!!!!!!
DaSpyda Avatar
Don Alexander
In reply to # 2118219 by riversidedan S.A.S. IS A VIRUS!!!!!!!!!!!!!!!!!
What is your source for that info????
Don
1970 MGB
2000 MR2 Spyder
Dan burnett
puyallup, USA   usa
forgot when it was but raised all kinda hell
