Off Topic Forum
Home heating oil tank volume....how to measure?
smirkinwill Avatar
smirkinwill William McCurdie
Royersford, Pennsylvania, USA   USA
1969 MG MGB "Lady Jane"
This has been bugging me for years. I've been living in this house for 28 years and back in 1988 I had to replace my oil tank . At the time, I could have sworn that the replacement tank was 250 gallons. However, the tank has a gauge on it and when it's showing flat out empty, and I have it filled, it'll take only 199 gallons. So either the gauge is off or I have a 200 gallon tank.
It's in my basement and I can measure it's dimensions, but how do I convert the measurements into volume?
Thanks.
1969 MGB "Lady Jane"
Gerry Avatar
http://www.referencedesigner.com/calc/cal_07.php
Use inches then divide the answer by 231 and you get gallons I think. Been a while for me
Edited 1 time(s). Last edit at 2010-01-11 08:53 AM by Gerry.
smirkinwill Avatar
Thanks Gerry.
Still a tad confused though.
The tank measures 60" across (I'm using that as the height on the calculator)
For the radius, if I'm doing this right, I measured across the end in the middle and it's 27". If I halve that for the radius and go with 13.5" I get an answer of 34353.287.
Not sure what that is in gallons.
Gerry Avatar
works out to 148 US gallons
Is the tank a true sphere? Seen some that were oblong in cross section. This method would come out low if the tank is not round
smirkinwill Avatar
Thanks again Gerry.
It is oblong. Here's a few pics.
(My wife painted it and chose the color....not me!)
IMG_7979.JPG    34.2 KB
smirkinwill Avatar
one more.
IMG_7980.JPG    20.3 KB
smirkinwill Avatar
looks like this one.
oil_tank.jpg    9.4 KB
Gerry Avatar
That tank is not a cylinder. You will have to add the volumn of the strait sides to the 148 gallons to get a real number. Measure the width and height of the square section and multiply them together then devide this number by 231 then add the result to the 148 mentioned above. I suspect you have a 275 gallon tank whick is pretty much a standard according the the web sources I found
Gerry Avatar
Look here for more tank info
http://www.ableenergy.com/se/capacity.asp
Man I'm glad I don't live where oil is used as home boiler fuel
nchokie Avatar
nchokie R.D. Williams
Clewiston, Florida, USA   USA
I think you can plug in three dimensions into this calculator and it will give you the volume of the liquid in the tank at different levels of "fullness"
http://freeonlinecalculator.net/calculators/construction/tank.php?action=solve&last=cyl_h&given_data=oval&h_ft=&h_in=&d_ft=&d_in=&fill_ft=&fill_in=[url/] R.D. Williams
Gerry Avatar
There you go-that should do it!
smirkinwill Avatar
OK, I'll go with that.
And yes, be glad Gerry......cost me $525.00 for 199 gallons today. Should last 3 months or so.
britcars Avatar
britcars Phil Ossinger
Fredericton, New Brunswick, Canada   CAN
In our part of the world, I sometimes hear about a basement oil tank leaking and causing all kinds of problems. Old steel tanks usually rust through the bottom. I believe that new and replacement tanks here must be double walled. A lot of them are now fibreglass. The Environment Dept. requires cleanup which can run into huge dollars.
The local paper reported recently that one home was demolished as the cost of cleanup and soil remediation exceeded the house value many times over.
Adventure before Dementia.
The older you get, the more important it is not to act your age.
smirkinwill Avatar
That did it R.D.
Works out to roughly 275 gallons like Gerry figured. Thanks all! Guess the gauge is off by quite a bit....sort of like my GT's fuel gauge.
And Phil, yes I did have to replace the old tank back in 1988. I had just had it filled and happened to be in the basement when I smelled fuel oil. Looked near the bottom of the tank and saw what I thought was a drop of oil. Turned out it was a bubble in the paint. When I touched it, a tiny stream of oil started coming out onto the floor. I grabbed a faucet washer and a self tapping screww and that held long enough to get it replaced. They had to pump out the tank, and put in the new one & refill. If that had happened in the middle of the night or if the leak was on the wall side, it would have been a real mess.
There was an incident here a few years ago where a homeowner had replaced his oil heater with gas. Seems nobody told his regular oil company and under some contracts they come out and fill automatically depending on "degree days". Well, the oil guy hooked up his hose to the outside fill pipe and pumped quite a few gallons of fuel oil into his basement. That smell in small quantities is tough to get rid of. Not sure how it worked out for him.
Gerry Avatar
Just curious-do you have any problems with sludge in the tank bottom? Down here in the south sludge/water is sometimes a problem in out diesel storage tanks. What kind of level indicator do y'alls tanks use?
