TD fuel tank end cover leak.
Namsutol Kearney Kevin
Cabin John, MD, USA   USA
Presently converting from fuel cell to standard fuel tank. The bolts that hold the tanks end plate covers , one of them goes through to the inside of the tank.
What fuel proof sealant can I use on the threads?
I will be using locktite 515
Hawkmonster Avatar
Hawkmonster Joe Policastro
Flagstaff, AZ, USA   USA
To the best of my knowledge those screws do not go into the tank. The tank has a captive nut. I have mine on for years with no leaks and the there is no loosing of the bolt due to vibration. Make sure you have the proper length bolt.
See picture to make sure we are discussing the same bolts.
Joe
Edited 1 time(s). Last edit at 2018-02-14 11:07 AM by Hawkmonster.
image.jpeg    35.6 KB
TD4834 Avatar
TD4834 Bill Chasser
Sacramento, CA, USA   USA
They side plate bolts should not go through the tank bulkhead
