TD Rear Number Plate Support Bracket
Sam Suffi Malcolm McConnachy
Littlehampton, West Sussex, UK   GBR
My 1950 TD has a weird rear number plate support bracket which bolts on top of the spare wheel. It is very heavy and agricultural.
I don't suppose this is an original piece, what was normally fitted?
Thanks
IMG_20180112_114553.jpg    37.8 KB
IMG_20180112_114648.jpg    37.9 KB
LaVerne Avatar
LaVerne LaVerne Downey
Fruita, Colorado, USA   USA
1954 MG TF "Green Hornet"
Not sure what you have...originally the were mounted on the drivers side as shown .
2442_crop_crop.jpg    51.3 KB
IMG_4390.JPG    39.4 KB
IMG_4403.JPG    57.2 KB
In reply to # 3660411 by LaVerne Not sure what you have...originally the were mounted on the drivers side as shown .
Thanks for the photos LaVerne, shows what should be there.
I think I'll just leave it the way it is and fit a rear fog light on the lower protruding part of the bracket, luckily I ran a spare conductor in my home made (N to S) wiring harness so can use that as a power supply,
LaVerne Avatar
Here's the rack mount Malcolm . If your car is RHD then it would be on the opposite side
Edited 1 time(s). Last edit at 2018-01-12 06:10 PM by LaVerne.
mg td (37).JPG    49.8 KB
