Rear Tranny Mount Orientation
  This topic is about my 1955 MG TF 1500
BuilderBob228 Silver Member Robert Weinstein
Winnetka, Illinois, USA   USA
Can someone please tell me if the rear tranny mount pictured below is orientated with the A or B side facing the front of the car.?
My apologies if this has been posted twice. I did not receive any responses and count not find it on the list of posted questions.
thanks
robert
PIc of trans mnt for forum.jpg    21.9 KB
LaVerne Avatar
LaVerne LaVerne Downey
Fruita, Colorado, USA   USA
1954 MG TF "Green Hornet"
To be honest I don't remember, but if you hold it up to the gear box bolt it will become evident which way it has to be mounted.
thx. will look against tranny later today. am I better off putting the mount on the tranny before I install it, assuming I can get it compressed enough to do the bolt ?
Lonnie Cook Avatar
Orlando, Florida, USA   USA
This is the mount on my TF gearbox. The tail piece is at the top of the photo. Yes, install the mount, rubbers, and fork onto the gearbox before installing it into the car.
Lonnie
TF7211
OLD STUFF ... houses, furniture, cars, wine ... I love it all
Mount-AS.jpg    49.7 KB
Mount-AS2.jpg    54.2 KB
Thanks very much to all
Robert
Lonnie Cook Avatar
Make sure that the welds in the corners of the bracket are good. Chamfer all corners of the rubber where they meet the inside corners of the bracket so that the rubber sits flush to the bottom of the bracket. The cup of the cupped washer faces away from the bracket so that its edges don't contact it.
Lonnie
TF7211
Lonnie
Hard to see in the picture, but i gather the rubber goes below the bracket? Is this to cushion the transmission when it moves upward?
t
r
LaVerne Avatar
The rubber block sits between the gearbox and the bracket. The assembly is then offered up to the gear box bolt and held it place with with the rubber grommet and cupped washer . The bracket is bolted directly to the frame mount.
My bad, poor use of terminology.
Just want to confirm that moving downward from the tranny comes the blocks in the bracket (with the bolt on the U connector), then the small rubber grommet below the bracket, then the metal cup (convex side to the rubber) and then the castle nut and cotter pin.
Right?
LaVerne Avatar
Thats correct
