New angle drive
Declan Burns Avatar
I have a new design angle drive gearbox almost ready for testing. It is a modular bevel angular gearbox that is fitted to the car gearbox and not the speedo as my other gearboxes. I will be able to do them with Ford inputs and outputs or XPAG inputs and outputs or a combination.I have attached a a photo of the prototype with the lid removed. It's going in my mate's Midget on Friday.
It runs like a Swiss watch!
The bevel gears run in roller bearings seated in bearing caps and the bevel stage is always the same regardless of the input or output configuration.
I will next build the version with the integrated speedo corrector stage. It will be slightly larger but only by 10mm.
The advantage is that it comes out of the gearbox at 90° parallel to the gearbox and has no nasty bend in the cable. With a FORD input and an XPAG output you can still use the original cable.
Regards
Declan
Ford_angle_drive_6.jpg    32.5 KB
Speedogear_bevel_quad_tube-Model.pdf    45.3 KB
AZTD Avatar
Glendale, Arizona, USA   USA
1953 MG TD
Reverse the in - out put to make it right.
So it turns the same direction.
Looks great. good work
thx
1953 MG TD TD23816
Declan Burns Avatar
The bevel does or does not change the direction of rotation depending on which end of the long shaft you connect to.
I have connected the input and output on the wrong side!
That will give me something to do tomorrow.
Regards
Declan
Declan Burns Avatar
I corrected the input and output configuration this afternoon-now it is correct.
I have also made a 3D drawing of the housing and my mate has ordered a 3D printer so we are going to see what the housing turns out like.
Regards
Declan
Ford_angle_drive_9.jpg    31.9 KB
