1950 TD Floorboards
Sam Suffi Malcolm McConnachy
Littlehampton, West Sussex, UK   GBR
I'm sure this has been discussed often in the past, so,excuse me for raising the topic again, but, "Is the overall outline of the two floorboards the same?" (apart from the miscellaneous cut outs) i.e, one being a mirror image of the other.
I have one reasonable passenger side floorboard (RHD car) which I can use as a pattern, I have also seem some detailed drawings on the internet for the cut outs.
Just bought a 8ft x 4ft sheet of 12 mm Baltic Birch Ply, so I'm ready for the off.
Cheers
There you go
Yours sincerely, Thierry de l'Ardèche, France
MG TD Floorboards Rev 4.pdf    94.7 KB
Thanks Thierry,
Ça me suffit.
Sam Suffi
Trial fit of the passenger side floorboard. Seemed to fit ok. Drilled up from underneath through the chassis bolt holes to get good fastener alignment.
My only regret is cutting out the square notch for the bolt head at the front of the secondary chassis member. A recess in the board would have been a neater solution.
Next up is the tricky, drivers side board.
P1030213.JPG    38.8 KB
1973 MG MGB GT V6 Conversion
