Buy, Sell & Trade Forum
Mystery Differential - dated August 19, 1955 [California, USA]
ccbweber Craig Weber
San Francisco, California, USA   USA
I obtained this differential from a MG repair shop. The Ring gear is labeled "DANA" 18515, A3R9.
The gear ratio is 11/41 (3.73:1). Hope someone can help me identify it. I would like
to see it used in a restoration project. The hangers look much like the MG, however
definitely not a MOWAG.
Thanks
IMG_0738.JPG    49 KB
IMG_0740.JPG    62.1 KB
GILMGA Avatar
CHATTANOOGA, TENNESSEE, USA   USA
1962 MG MGA
1974 MG MGB GT
3.27 ratio 41 11 Might be some kind of racing diff.
Gil
76lucas Avatar
76lucas Gold Member Josh L
Floyd, VA, USA   USA
1978 MG Midget 1500
Numbers in front of Dana are the date code. The ones right after are the part number for the ring gear. And has Gill said the last one are ratio. Although the site I found calls it a 3:73. That ring gear is common for a Dana 44 axle used in smaller four wheel drives such has a jeep. Oh and the A3R9 is a heat batch code, Seems swapping a dana 44 in a b is or was a common practice. Might be why they had it. http://www.mgexp.com/phorum/read.php?40,2566114
