MG Motorsports Forum
"Paddy Hopkirk" accelerator mod
mgcyclo Avatar
mgcyclo Tim Rich
Township of Washinghton, NJ, USA   USA
I'm trying to get a better pedal set up for heal-toe. This winter I adjusted the accelerator pedal so it and the brake pedal are level while under braking but I still can't roll my foot as easily as I would like to heal-toe. I can get it right like once every 5 or 6 attempts and I have to think too much while doing it.
A few years ago I bought a Paddy Hopkirk pedal but mine is a 1970 so the pedal wouldn't work. I sent it back so no longer have it to use as a template.
So my question to you all, what is your advice to modify the accelerator pedal to suit my needs. What are the critical reference points, measurements, materials, etc. is there an off the shelf item, DIY?
Advice / direction appreciated.
PS: I've spent time on Google but I think real world advice for something like this from experienced users is better than a picture.
Best regards and thanks in advance
Tim
ghnl Avatar
ghnl Eric Russell
Mebane, NC, USA   USA
1961 MG MGA "Calvin"
In my MGA it is not really heel & toe but more ball of big toe & right side of foot. I did add a home-made 'Paddy Hopkirk' pedal to make the accelerator pedal a little bigger then original postage stamp size pedal.
Eric Russell ~ Mebane, NC
dipstick Avatar
dipstick Kenny Snyder
La Center, WA, USA   USA
1941 Ford N-Series
1970 MG MGB GT "Pat's GT"
Google summitracing.com, enter gas pedal into the Summit search engine. There are many extensions available.
Be safe out there.
Kenny
200mph Avatar
Winston-Salem, NC, USA   USA
Tim,
I adapted a Paddy Pedal to my Spridget... be glad to send you a tracing of the pedal outline if you wish.
Anything that enlarges the pedal surface will be helpful. You can probably fab one up out of steel or aluminum stock and bolt it to the existing pedal.
"Have you ever thought... Everyone driving slower than your MG is a MORON, everyone driving faster must be a FREAKING IDIOT!". . . George Carlin
Redford (Detroit), Mi., USA   USA
Hmm,,, I thought the Paddy Hopkirk thottle pedal assist was a 12 lb boot ?? LOL.................
Dave
NaDaDawgRacer John Jones
Waxhaw, NC, USA   USA
Here is the large peddle I made. You can see the screws where I screwed it to the existing peddle. If you look close you can see the bend I made just below the bottom screws to make it more comfortable. I was concerned about the additional weight on the throttle return so I put an additional spring on the throttle linkage.
IMG_1426.JPG    26.3 KB
mgcyclo Avatar
mgcyclo Tim Rich
The Sparco Corsa pedal set that I ordered showed up today ($29 Amazon). I may have to work on forming it to match the bend of the pedals or machine a spacer or similar but I'm now at least half way there!
PS: it's made of mild steel so bending it to the same curve of the existing accelerator pedal should be easy if I want to go that way.
image.jpg    33.8 KB
erickz Avatar
erickz Erick Zanner
Columbus, OH, USA   USA
1973 MG Midget "Midge"
1973 MG Midget MkII "Midge"
I bent my brake pedal a little towards the accelerator - use the left side of my foot, think ball of your foot under your big toe and then simply roll your foot to hit the gas. When you get the set up right it is a really enjoyable experience. Have fun!
mgcyclo Avatar
mgcyclo Tim Rich
Thanks Erick
I'm close to mounting the pedals. Got sidetracked with some sciatica so not in the best shape to curl up in the footwell just now...
erickz Avatar
erickz Erick Zanner
The British Racecars site (you'll have to Google it - cannot remember the correct name) has a picture of Mr. Prather's SCCA MGA race car that uses an old style can/bottle opener welded onto the gas pedal. With all the success he has had with that car it must definitely be the hot setup!
