MG Motorsports Forum
Pulleys, vintage race MGA
Posted by malcox
malcox Avatar
Malcolm Cox
Napa, California, USA   usa
I recently blew up a second alternator (those lawn tractor alternators don't like 9000 rpm !), so clearly I have to do something about the pulley(s) ratio.
Does anyone supply a smaller crank pulley for a B series motor?
( second topic is a torsional damper necessary ?)
Is there available a larger water pump pulley?
(I hear that water pump cavitation may be an issue >6000 rpm)
Does anyone know the pitch diameter of the standard crank and water pump pulleys?
Any ideas on sourcing a larger pulley for a Nippon Denso alternator?
Malcolm and Diane Cox
Napa, CA
1960 MGA, #80
blackmgb Avatar
Fred McConnell
Hollidaysburg, Pennsylvania, USA   usa
1992 Mazda Miata NA "MAC"
Why not lose the alternator? This is exactly why I've always ran a total loss system. One less thing to break and screw up my weekends.
2012 SCCA FP MARRS Champion
malcox Avatar
Malcolm Cox
1 weekend, 1 car, 2 entries, 2 drivers = alternator
I tried total loss but I spent all my time hooking up a charger and back to back races were often marginal.
BTW, I estimate the alternator was actually doing 12,000 rpm!
Malcolm
Steve64B Avatar
Steve Opitz
Phoenix, AZ, USA   usa
1966 MG MGB
You can get larger pullyes for the alternator at Summit or Jegs
Edited 1 time(s). Last edit at 06/03/2012 01:13AM by Steve64B.
blackmgb Avatar
Fred McConnell
I understand Malcolm. I run a yellow top Optima and only put a charger on it once a day for a couple of ours. but, you also have to have power. I didn't test it, but I could probably get a whole weekend without a charge.
While at home the battery remains connected to a trickle charger.
fast-MG.com Avatar
Dave Headley
Cortez, 4 corners, Colorado, USA   usa
I ran a large orbital battery which also served as ballast. I could and sometimes did change it out in about 10 mins.thumbs up smiley
Fast-MG.com Dave Headley, dba FAB-TEK offers full service race car parts and preperation for MGB & MGA race cars, SCCA and Vintage. Dave is a mechanical engineer and has raced MGBs since 1963.
Bob Lembcke
Florida, USA   usa
On the Elva (vintage/1622), I ran a lawn tractor battery for years in a total loss system. Got tired of having to find way to charge, etc., then SVRA put 25# wt. pentalty without chargings system, so found a small, 35A, single wire alternator off some type of Indian (from India) fork truck, with my local alternator rebuilder (now there is a business area that is going away, too). Used the large Moroso pulley from drag race guys, Summit or such. Added holes in pulley to get air into/out of alternator. (drilled on angle...supposed to act as impellor for air.)
Have seen several Jap. Alternators out there, special built for high speeds...(I used to twist the 1622 to 8500+, haven't seen that for last few years...guess down on power or it's different...). If you don't care/want a built in regulator, think the RX7 stuff (external regulator) also did pretty high speed in street trim.
Personally, I'm a firm believer in the crank dampeners. Currently have aftermarket on from APT.
Will try to attach photo of engine with alternator and external oil pump...
Bob L.
Dick Moritz
Philly 'burbs, PA, USA   usa
Malcolm,
I run a dedicated Bosch 1-wire racing alternator. It is specifically designed for racing, only 55 amp output which is plenty for racing, only achieves significant output at higher rpms, and is designed for very low parasitic drag even at racing rpms. Came with pulley installed, has been problem-free and, IIRC, was not very expensive, at about $175 I think.
bills Avatar
Bill Spohn
The generators are a waste of time in high RPM applications, not just because they have higher drag than an alternator, but because you will spin the guts out of them. You can get by using a larger pulley (that's what they did on the Twin Cam in stock form), but a lightweight alternator would be my choice.
I refuse to run without one - too damned inconvenient if you spin on the circuit and can't restart because the battery is low - a friend lost a championship that way.
West Vancouver BC
