MG Motorsports Forum
Headers To wrap or not to wrap - Cnsnsus?
Posted by bluemij
bluemij Avatar
Neil Janota
No. IL, USA   usa
I know there are a lot of pros and cons to wrapping headers. Anyone wish to offer a recommendation?
blackmgb Avatar
Fred McConnell
Hollidaysburg, Pennsylvania, USA   usa
1992 Mazda Miata NA "MAC"
I wrapped mine because I did not have a normal heatshield. The heatshield when in place makes the car more complicated to work on and we set up the intake/carbs to come off in one piece and not having a heatshield made everything all around easier.
2012 SCCA FP MARRS Champion
Bandit Racing Avatar
Donald Dickey
Illinois, USA   usa
1963 MG MGB Racecar "#99 BRG Vintage Racecar"
1965 MG MGB Racecar "#10 Huffaiker/ British Leyland"
Do not wrap. Headers that have coatings on both the inside and outside are the way to go.
Michael MacQueen
College Park MD, USA   usa
Ditto on the quality, high-temp coatings.
Rick Starkweather Avatar
Raleigh, NC, USA   usa
Don, Michael:
Who did you use for the hi-temp coatings? Want to send my headers out ASAP.
Rick
Donald Dickey
Illinois, USA   usa
Rick
I use Jet Hot. They have a multitude of types and colors.
Michael MacQueen
Swaintech. Not cheap, but good and durable, and pretty quick turnaround time too.
dcharnet Avatar
Donald Charnetski
Grinnell, Iowa, USA   usa
1963 MG MGB
In reply to # 2048065 by bluemij I know there are a lot of pros and cons to wrapping headers. Anyone wish to offer a recommendation?
The ONLY "pro" I have ever heard for wrapping a header is when one racer's motor caught fire, the smoke from the wrapping, now itself on fire, tipped him off early. Not really a pro.
Ceramic coat, don't wrap.
And, you usually get what you pay for.
Greenville, SC, USA   usa
1967 MG MGB "The Biscuit"
I wrapped my headers for 30 years, but what do I know grinning smiley
dcharnet Avatar
Donald Charnetski
1963 MG MGB
In reply to # 2048313 by Speedracer I wrapped my headers for 30 years, but what do I know grinning smiley
Hap, as I see it, this presents a golden opportunity for you. Get this one header wrap thing right, finally, and then you will know everything.
Don
In reply to # 2048516 by dcharnet
Don
Ah, Don, I don't know it all, but not for lack of trying smiling smiley
Maybe Neil, didn't want to spend a couple hundred dollars or more on ceramic coating his header and wanted to know if the coating added HP, or wrapping a header loses HP, not what's in trend for this year's racer, but rather does it work or hurt. The bottom line is ceramic coatings typically burn off the first few inches of the header over time, but they are getting better, and wrapping a header, serves no disadvantages in header durabilty or HP loss, or gain, unless keeping heat away from the carbs is a gain, and both methods do that. So Neil I wrapped my headers for years, I normally re do it ever 2-3 events, and clean the headers well each time I do it, I clean the headers with scotchbrite and then coat them down with WD40, then wipe it off. When I wash the car, and engine bay, like I did this past weekend, I like to crank the engine up afterwards and let the header heat up and get the water out of the wrap from washing the engine bay, and when the wrap is brand new, it goes thru a curing stage the first time you crank the car up, and will smoke from the wrap, and stink, it's best to do this outside, after it cures that first time, it will not do that again. Bottom line is, header wrap does what it claims, keeps heat away from your carbs, and does not do anything to hurt performance.
Edited 2 time(s). Last edit at 04/24/2012 06:04AM by Speedracer.
dcharnet Avatar
Donald Charnetski
1963 MG MGB
Hap:
Both my FF and FV had good quality ceramic coatings inside and out. The coating on the FF was many years old and showed no signs of deterioration of any kind. I double-coated the Vee when I built it in 03, and when I sold in '11 it was in perfect shape. All I ever did on either was quickly wipe the surface with WD 40.
What I read from neutral, authoritative sources is that ceramic coating absorbs no heat. It keeps the heat within the tube and forces it out the exhaust, whereas header wrap absorbs the heat and holds it, right where you don't want it. The higher ambient temp outside the header with header wrap has been confirmed with simple testing. That is HP lost, pure and simple.
Header wrap will rust a header unless, apparently, you remove it and do what you do. I know this from personal experience on a BMW 2002.
What do high-tech pro engine builders and upper-level race teams do? I have not researched this, but I suspect that with the introduction of ceramic and other coatings, no one at that level uses header wrap. Why?
Initial lower cost is the only reason I can see to use it. Other than that, why do you think it is the better choice?
Don
Edited 1 time(s). Last edit at 04/24/2012 07:48AM by dcharnet.
Don, sorry ain't buying it, says the man who works on his own car.
dcharnet Avatar
Donald Charnetski
1963 MG MGB
In reply to # 2048837 by Speedracer Don, sorry ain't buying it, says the man who works on his own car.
Hap, I don't do this for a living like you, but except for rebuilds, I work on my own cars just like most of us do, and have been fussing with this stuff long enough to know which end is up. I have high regard for your general expertise, but think that you are wrong on this point. This forum is about public discussion and analysis. We can let the content of his thread speak for itself, leave it at that, and not get into a £¥+|<% match. I value communication with you too much for that.
Don
bluemij Avatar
Neil Janota
No. IL, USA   usa
My main interest is to reduce the heat near the carbs, and also, hopefully, reduce overall temperature under the hood. Spridgets are notorious for retaining heat in the engine bay, and most organizations don't allow hood venting.
bluemij Avatar
Neil Janota
No. IL, USA   usa
Just want to thank everyone (particularly Hap and Don)for contributing learned opinions to this thread. These kinds of diversified opinions are great for sharing real life experiences that will ultimately help myself and others make good choices. smiling smiley
Don, my remarks to you were a bit of mean spritied and I have say I'm sorry for that resopnse, it's been tough morning and I'm having to deal with some totally stupid BS, thats ticking me off, and I took it out on you. Now that being said, I always of the opinion, there's more than one way to skin a cat, and I think we proved you can have spme pretty fast cars with header wrap on them, everyone is due an opinion, and we both have one. It's not that I'm against cermaic coating a header, I just not of the opinion header wrap is evil, or a HP robber.
dcharnet Avatar
Donald Charnetski
1963 MG MGB
In reply to # 2049071 by Speedracer Don, my remarks to you were a bit of mean spritied and I have say I'm sorry for that resopnse, it's been tough morning and I'm having to deal with some totally stupid BS, thats ticking me off, and I took it out on you. Now that being said, I always of the opinion, there's more than one way to skin a cat, and I think we proved you can have spme pretty fast cars with header wrap on them, everyone is due an opinion, and we both have one. It's not that I'm against cermaic coating a header, I just not of the opinion header wrap is evil, or a HP robber.
Hap, thanks, but no need for an apology. I understand what you are saying, and I do love an intense exchange, especially with you. Hope your day goes better.
Don
Steve64B Avatar
Steve Opitz
Phoenix, AZ, USA   usa
1966 MG MGB
The data is on the internet, this is a synopsis from several different articles.
In an actual tests this is what has been discovered about coatings and header wrap.
On a dyno neither produce extra HP. This may not hold true on track because the air feed in the dyno is controlled and unaffected by the heat generated in motor operation.
Ceramic coatings lowered radiated temperature on 304 SS by roughly 15%
Header wrap lowered the radiated temperature by about 20%
The coatings protect the metal from corrosion… the kind caused by header wrap.
Coatings extended parts life… header wrap shortens parts life.
It would appear that it’s not a case of either / or. Coat your header first for protection, then wrap it for increased insulation. The net gain could approach 30% to 40% lower underhood temperature, which could provide improved performance.
For street use header wrap also quiets header ring.
blackmgb Avatar
Fred McConnell
I would pull the engine at least once a year, or more, so the headers always got a fresh coat of paint. They did not have any coatings on them.
My new headers do have a coating. None of this stuff is cheap, so doing what keeps them lasting the longest is not a bad idea.
