MG Motorsports Forum
Adjusting rear sway bar
Posted by EDs 78
EDs 78 Avatar
Eric Duram
Lowell, mi, USA   usa
What is the best way to setup a rear sway bar? I put new poly bushings in the end links and poly in the mounts. How tight does the bar need to be when the car is sitting on the suspension? Should the bar have to be pulled forward slightly when putting in the end link bolts? What is a good way to make sure that both sides have even tension? As always Thank you to all for the help!
Regards,
Eric
Dick Moritz
Philly 'burbs, PA, USA   usa
Buy an adjustable rear sway bar from Dave Headley (fast-mg.com). He'll talk you through the simple adjustment procedure...
EDs 78 Avatar
Eric Duram
Lowell, mi, USA   usa
I put on his Drop-Spindles and shaved the front springs the rear has restacked leaves and blocks. The front already has a 7/8" sway bar the rear is the stock size bar with the ends that thread on. In the past for other cars I havn't seen any method of setting up sway bars. Its very strange that the new bushings didn't have any info they are from Energy Suspension.
fast-MG.com Avatar
Dave Headley
Cortez, 4 corners, Colorado, USA   usa
I've never done anything with, or seen one for that matter, the factory rear bar. So I'm afraid I can't help. I doubt that it came with adjustability unless you want to modify the mounting.smileys with beer
Fast-MG.com Dave Headley, dba FAB-TEK offers full service race car parts and preperation for MGB & MGA race cars, SCCA and Vintage. Dave is a mechanical engineer and has raced MGBs since 1963.
