MG-2013 is only 51 days away! · Corvallis, OR · July 17–21, 2013 · Visit MG-2013.com or the MG-2013 Forum for more info
MG Motorsports Forum
Spridget Gearbox question
Posted by saysprite
saysprite Avatar
Darryl Saylor
TN, USA   usa
1953 Austin-Healey 100 "Ole Blue"
1960 Austin-Healey Sprite Bugeye "Smokey"
1965 Austin-Healey Sprite "Porky"
1965 Austin-Healey Sprite "Speedracer"
1970 MG Midget "Jack"   → more
Is there any tricks on getting the third gear off the shaft? I know you're suppose to push in the spring and turn the clip. WHen I get the spring pushed in, I can't turned the retaining clip. Any suggestions?
Thanks
saysprite Avatar
Darryl Saylor
TN, USA   usa
With the help of my assistant. we got it off. Now the next question. Does anybody sell new 1/2 moom thrust washers. Moss UK has NLS, VB does not have them listed. One of mine cracked.
Dick Moritz
Philly 'burbs, PA, USA   usa
Darryl,
Not sure which box you're working with. MiniMania has the thrust washers for the 948 and 1098 boxes, not for the 1275 ribcase mixer...
Greenville, SC, USA   usa
1967 MG MGB "The Biscuit"
Darryl, you might want to give Freddy T., or Mike Miller a shout.
Edited 1 time(s). Last edit at 12/29/2011 04:53PM by Speedracer.
hpmowog Avatar
Karl Keiger
Covington, LA, USA   usa
Darryl,
I've got plenty of used ones that you're welcome to if you want. Shoot me a PM.
saysprite Avatar
Darryl Saylor
TN, USA   usa
I'm trying to build a SCCR box for a Spridget. My old one is jumping out of 2nd and 3rd gear. I got a used set of gears a few years ago. I was going to let Miller rebuild it but I want to learn how to do it myself.
Karl, sending you a pm.
Michael MacQueen
College Park MD, USA   usa
The most important thing in the garage, for the do-it-yourself trans builder, is to have one or two old transmissions broken down for parts. You can never tell when you'll lose one of the needle rollers or some other small bit. Plus you'll have a supply of thrust washers, locking pins and other obscure bits whch are no longer stocked by any of the parts houses.
Bob Lembcke
Florida, USA   usa
Daryl
Factory sraight cuts have no/little axial load, so nothing is pushing them in one direction or the other, any slop, they pop (out).... ball detents normally aren't the issue...those have to be really bad... it more, stuff that moves or giggles when rotating... helical gears provide a bit of thrust that keeps things together, where SC's don't.
What I almost always found to be cause of popping out of gear was axial clearance on the cluster stack up, or worn/bad synchro teeth on hub id....look at both mating parts, dress teeth with jeweler's files or dremel as needed...no burrs.. Do a good visual on stuff. Those thrust washers your sought, could be issue, as are shims in front of brg. on main shaft out...(between gear stack and brg...)
Also, make sure the pocket brg between first and 3rd motion shaft is good...including the shaft itself...often wear/brinell under brg, or inside first motion...
Use good stuff... the used gears, might be good or not....same with everything else. I had to buy new slider(s) from Leyland to fix my H car back in 78....
Some you just never figure out...
Okie
Edited 1 time(s). Last edit at 12/30/2011 11:13AM by Elva Bob.
Mark Derry
Chicago, USA   usa
Daryl
I'm going through the same thing this off season.
After two seasons of running a standard ribcase that I rebuilt myself all those hasty fourth to third changes accompnaied by loud grinding noises have taken their toll.
At the end of last season the popping out of third was becoming a little disconserting.
Please pass on any findings.
Also if anyone out there has a good used SC gear set I would be interested.
Good luck
Mark
Michael MacQueen
SC gearsets from Moss Europe are running less than $600, depending on the exchange rate (which has been increasingly favorable lately). Simple internet order -
USA   usa
Did you ever reach a conclusion in your rebuild Darryl? My dad and I have been struggling with the same issue with 3rd popping out and after a couple of rebuilds have yet to solve the problem...
One thing we have noticed is that when 3rd is engaged, the shift lever doesn't seem/appear as far forward as when 1st is engaged. It does however seem/appear to engage just as far as 1st on a stock ribcase. Anyone else notice that or chime in on that?
Tad
Michael MacQueen
Did you use the new style output shaft ball bearing? If so, you have to make sure the supplied shims are installed in such a way as to make the inner race stand out exactly to the height of the forward face of the inner race of the old style bearing. I ended up using a good used old style bearing (NLA) and this fixed the 3rd gear engagement problem.
saysprite Avatar
Darryl Saylor
TN, USA   usa
not yet, between the Holidays, being cold, work stuff, family stuff and motivation, i've taken a few weeks off. Everything is sitting there ready to be put back together. I just haven't started yet. I just have to get my butt back in gear.
