Cutting the car to make a V8 swap work
mster50 Silver Member Mike Sterling/A
Zanesville, OH, USA   USA
How far has anyone cut on a MGB to make a V8 engine fit? I was looking and measuring my MGB pondering a V8 swap for a small block Chevy engine. It is a very tight fit and most conversions run the exhaust through the inner fender well. There is an enormous amount of floor length in the B. More than needed, I think. It seems to me the seat could go back 4 to 6 inches, making the foot boxes that protrude into the engine compartment unnecessary. The heater box could go under the dash and the heater shelf and foot boxes could be cut out. Panels could be fabricated to patch the firewall, or a nice one piece firewall installed. The outside frame and the inner frame would need re-braced back together, I figure that was one on the functions of the foot boxes.
This would give room in the bell housing area for engine, starter, and exhaust clearance.
Any body ever gone this far?
mowog1 Avatar
Saint Joseph, IL, USA   USA
1969 MG MGC "Vicky"
1972 MG MGB "Mallard"
I suggest you visit http://www.britishv8.org
Lots of information there.
mowog1@aol.com
BC, Canada   CAN
Almost every one here who does the V8 swap, does it that way. What I do not understand, is why no one simply extends the wheelbase. It requires far less cutting up of the car, and does not require a short driver..
NOHOME P P
O, ON, Canada   CAN
Must be a Canadian thing...
Engine right up against the firewall, no heater and seat was up against the rear bulkhead. It was a low-buck,rat-rod project, but it rolled out.
Using the original MGB suspension and brakes, it was budgeted at under 5k Canadian
Pete
"Almost every one here who does the V8 swap, does it that way."
Presumably you mean "Almost every one here who does the Chevy V8 swap, does it that way."?
IDK if that's true for other V8s but no cutting for my Rover V8 - but I did deliberately buy the body the Factory used for their 3.5.
"What I do not understand, is why no one simply extends the wheelbase".
Here that's a no go area.
Edited 2 time(s). Last edit at 2017-11-19 06:37 AM by MGB567.
NOHOME P P
O, ON, Canada   CAN
In reply to # 3630049 by Richardtherodder What I do not understand, is why no one simply extends the wheelbase. It requires far less cutting up of the car, and does not require a short driver..
I did a wheelbase stretch on the current project. Not something I will advocate for doing again.
I see these car have been modified from None to "that's not a MGB anymore".
I think Richardtherodder meant almost everyone runs the exhaust through the fender well.
I just don't like the exhaust in there with the tire.
Why is changing the wheel base a "no go" area here?
NOHOME, your not afraid of anything are you? That was a bold project, I like it. I see your garage is well equipped for the big projects.
Is that an American flag in Canada?
NOHOME P P
O, ON, Canada   CAN
In reply to a post by Mike Sterling
Why yes, it is! And if you look carefully you will see another flag tucked in behind.drinking smiley
Pete
In reply to # 3630496 by NOHOME
Pete
British? What era? If that is lower left corner it does not match exactly any images I find.
Ryan Reis Avatar
Beatrice, NE, USA   USA
1968 MG MGB
You'd do all of that work just to avoid headers through the inner fenders? I guess you could shift everything rearward like that, but it's so much work. And I just think the further you sit rear from the windshield the sillier it's going to look. That's my problem with changing the wheelbase. My humble opinion - it's going to look out of proportion and weird. There are dozens and dozens of conversions running fenderwell headers with no issues. To clarify - I support doing what you want and I say go for it if that's your vision!
Ryan
BC, Canada   CAN
Nohome it looks like you cut the rails in the wrong spot. It looks like you were not just trying to extend the wheelbase. I did not do it because I do not have access to a shop, with a level floor. But I would have cut the rails, just before, where the wheel wells start. Then cut 1 slice down the fender, and put in a strip of metal. The only hard part would be to make sure everything is straight, when you weld it back together. And a simple jig would accomplish that. Then all that is left, is to lengthen the steering shaft. The funny thing is, several people here have done all that, but they left the wheelbase the same. So then they had to cut up the firewall as well. To me it does not make any sense. Unless they are intimidated by body work.
James E Avatar
Bedford, VA, USA   USA
Peter has done some work on these British cars that no one else would even attempt, Yes I remember Peter!
BC, Canada   CAN
Ryan, you want to see silly. People have told me that they laughed, when they saw me get out of my MG.
Jim Stabe Avatar
San Diego, CA, USA   USA
Pete.
I, for one, am happy to see others making dimensional changes to the MGB for whatever reason.
Windshield (8).jpg    44.8 KB
Pilot4747 Chuck Hall
Sumerco, WV, USA   USA
I found that a S 10 Chevy works great
1949 MG Y Type Saloon
