HTOB for an LT77
Walrus1954 Avatar
Walrus1954 Neil Peniston
Anyone know if there is a Hydraulic Throw out Bearing that can be used with the Rover LT77 box?
Cheers, Neil.P
Jim Lema Avatar
Seattle, Washington, USA   USA
1967 MG MGB
Have you checked with the Wedge Shop. They have lots of TR8 stuff that uses the LT77 transmission.
mgv8glen Avatar
mgv8glen Glenn Towery
Dover, Delaware, USA   USA
Neil If you won’t a real big Pain in tha ass, use a HTOB!!!!!! The O E clutch used in the LT77 has worked great in all the V8s I have built. Have used 2 HTO and had both leak, total junk in my book.
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
Then again, my McCleod HTOB has given no trouble for 16.5 years & counting. cool smiley
rmorgansr Avatar
rmorgansr Robert Morgan
Milford, Delaware, USA   USA
If it leaks it'll take longer to bleed it than replace it and the transmission's still in the car.
External Slave.jpg    34.7 KB
Walrus1954 Avatar
1. Glenn, Does the original slave cylinder (SD1) fit in the MGB with the LT77 transmission?
2. Carl, Do you have a part # for the Macleod HTOB ?
Cheers, NP.
Simon Austin Avatar
The SD1 slave cylinder fits in an MGB....and an RV8...winking smiley
I have the SD1 slave in my car. The RV8 I owned had the LT77 and the same slave cylinder.
Walrus1954 Avatar
Thanks Simon. Likely go that route .
Simon Austin Avatar
No problem, Neil. I'll be putting the car to bed soon on the lift so can pass along some photos if you like once it's in the air.
Walrus1954 Avatar
Simon, I would appreciate any photos you can take.
Thanks in anticipation.
Cheers, Neil.
Simon Austin Avatar
thumbs upthumbs up
