engine running hot
billhall Avatar
billhall bill hall
tucson, AZ, USA   USA
I don't get it, I just put in a new long block 3.4 l v6 engine in my mgb and it runs hotter than the old 3.4 I had in it before. The radiator set up is the same one as the old engine with a new water pump and thermostat. it doesn't get hot all at once it just slowly creeps up. with the old engine it would hold under 200 now it just keeps slowly creeping up. Faster if iam driving hard but driving around 3 three city blocks I get the below picture temperature would sluge build up in the radiator cause this I had it tanked and when I placed it back on the old engine. when I did change the fluid after that it was very brown and rust colored as if it caused crap from the old engine to let loose in the system. I did flush it well before installing in the new engine even left some clr in it for a couple of days. before flushing and installing. I am curious what other peoples 3.4 l conversions operating temp runs at and why it slowly creeps up? thanks any input would be appreciated.
0B98F691-20E1-4023-85AF-8EF106FD3B63.JPG    42.4 KB
Check you timing.
Retarded causes heat issues.
Bump up the timing a few degrees, the book specs are hopelessly outdated.
GMATS Avatar
GMATS GERALD MATLIN
palm beach gardens, FL, USA   USA
You might have some air trapped in the engine. Take off the radiator cap and let the engine run up to temp and see if you get a lot of "burping". If you do it's air and once that stops your temp may be aok.
billhall Avatar
billhall bill hall
tucson, AZ, USA   USA
funny that you mention timing I just set it on fast and ideal and I cant remember what I left them at but I believe they where mid range on both. what timing do you suggest Rob?
Gerald I did try burping the radiator I even dropped the passengers side a little lower while on stands to get the neck of the radiator at a higher point it helped a bit I was able to make it around the block 3 times and not 2.
I pulled the radiator later during the day today and dropped it off to get tanked will see if that solves the problem. but it did give me a chance to change the pulley while I was at it now it has Bills water pulley that I had changed to a smooth profile to run on the back of the belt.
694DE545-AB58-4D9E-ACF3-602579139067.JPG    63.2 KB
cstrong45 Avatar
cstrong45 Silver Member Charles Strong
Bainbridge Island, WA, USA   USA
at what point does the fan come on?
billhall Avatar
billhall bill hall
tucson, AZ, USA   USA
They come on at 170 ish
Distributor timing at idle?
Total all in at ?
After you clean the radiator try approx 3-5 more degrees at 800rpm
And then go road load tune it like distributor ignition fired engine
billgknapp Avatar
billgknapp Silver Member Bill Knapp
Rochester, MI, USA   USA
1977 MG MGB "Nigel"
I love your gauge faces Bill
billhall Avatar
billhall bill hall
tucson, AZ, USA   USA
Sorry Rob,
I forget the correct terminology if I haven't recently reviewed it.
total timing was set at 2000 rpm and if I remember correctly I set it a 28 deg.
partial timing was set at 900 rpm at 8 deg, I believe. Both while engine at running temp with the vacuum line to distributor closed off.
I am a little confused with your road load tune comment can you explain it a little further.
Thanks again
Thanks Bill, The gauges are from VDO they all work fine except I haven't been able to get speedometer to work correctly. as soon as I get the overheating issue fixed I will try and reset it again. when I had the trany rebuilt I had the pulse sender checked over so hopefully that will solve that problem.
260mgb Jim Nichols
Sequim,WA, USA   USA
Bill, Try 10-12 initial, should be around 32-36 total all in at 2500 RPM. I've had better luck running manifold instead of ported vacuum. It must be limited to 8-10 and you will have to slow your idle back down.
8 is low
Spec is 10 and that's outdated on modern regular fuel.
Bump it up ,adjust idle.
Go out on a steep hill (no traffic) punch the gas at 2500rpm in 3Rd gear .Test response and listen for pinging under
LOAD no pinging try a few more degrees timing
Repete test. When it pings back it down to the last timing it didn't ping.
Your performance will be snappier and your cool will return.
190f-200f operating is dandy
Confirm with infra gun
Compare to gauge reading
billhall Avatar
billhall bill hall
tucson, AZ, USA   USA
up date on the overheating issue.
1. adjusted the timing 12 deg initial, and 36 deg for total timing, she is now very responsive
2. removed the thermostat to see if it was restricting water flow
3 tried water wetter and a 30/70 mixture of antifreeze/ distilled water
4 burped the engine with a radiator cap missing its internals in order to use the overflow tank as a reservoir.
she is still running hot in 100 deg plus weather. 220 by the time I get home from work, about 5 miles city driving. she runs fine on the highway 185 ish.. In the morning below 85 deg out side temp she is also running ok. I cant really think what is different this time around except that I had the headers ceramic coated to keep the inside cabin temps down, which did help the inside cabin temperature noticeably I will try it again tomorrow and close of the valve the heater core. temp outside should be 92 so will see if she over heats on the way home. I am considering changing to an aluminum radiator by Wizards even though they are pricy right now she has a stock with extra rows basically from what I remember the radiator shop that altered it,put as thick of a core as they could fit in the standard top and bottom tank.
rmorgansr Avatar
rmorgansr Robert Morgan
Milford, DE, USA   USA
This will probably start a flurry of responses, but try Evans Waterless Coolant. Amazing stuff..........BTW, buy some gas.
cstrong45 Avatar
Save your money on the aluminum rad until you find out what is causing the problem, its likely not the rad. Your fans should keep the air flowing enough to keep the temp way below 220 IMHO. I think you have a bottle neck someplace in the block that is keeping water from flowing enough to cool it.
billhall Avatar
billhall bill hall
tucson, AZ, USA   USA
lol Robert the tank has plenty of gas it has never marked over half a tank even thought the gauge is supposed to be calibrated to the same scale as the mgb sender. as far as ohms of resistance if I remember correctly.
Charles for the flow the water pump is a new one for a 93 Camaro and as far as I know 93-95 water pumps are all reverse flow for those years and the block is a new long block so shouldn't have any issues, I hope.
I am thinking of purchasing one of the radiators from ebay and having a local speedshop that has a good aluminum tig welder change the intake and output location/size to fit out v6 conversions any opinion on which would be the best one to alter. ie best fit on a 69 mgb and max cooling.
