Glenn's mounts and Fastcars frontend
I've previously written about the engine mounts I bought from TRS (below) and then I decided I would try a pair of Glen's with the objective of getting the engine as low as possible before shaving the plenum. Problem is my sump now rests on the xmember. The mounts all line up with the plates on the frame. If I go back to my TRS mounts I gain around 1/2" clearance (but the engine is raised). I could I presume put a spacer between the rails and xmember but the result would be the same. As far as I can see the sump needs modifying (my guru can do that - although we haven't checked what's in there internally) unless one of you has another idea,
Edited 1 time(s). Last edit at 2017-04-17 04:05 AM by MGB567.
trs mount.jpg    8.1 KB
plenum.jpg    33.5 KB
P1010488.JPG    27.8 KB
mstemp Avatar
mstemp Silver Member Mike Stemp
As your new front crosmember is already significantly lower than a stock unit something is wrong. What is the sump out of? Deeper than a Rover SD1 version?
Mike IDK what the sump came from; I asked the engine supplier (the same TRS as the mounts) to supply a sump so they just sent one they had. So the sumps are not all the same on Rover V8? If that's the case I'm going to need to do some searching of shapes and see if there's one with the same bolt pattern but slightly shorter in the drop down section. I looked at Rimmers options and they seem to be either NLA or there's a "use this part" option and this one for my motor doesn't look any different to what I have (although there's no dimensions) - and not cheap to buy on spec.
Edited 1 time(s). Last edit at 2017-04-13 07:39 AM by MGB567.
Ryan Reis Avatar
Beatrice, NE, USA   USA
1968 MG MGB
I'm not sure how much space you need to clear, but I think it would be fairly simple to modify the pan. Bolt it down to something solid to prevent any warpage, cut a section out and weld in a relief. As you point out you need to see what's inside, but I'll bet there's enough space to get you the clearance you need. Raising the engine or lowering the crossmember are both compromises I wouldn't want to make.
Ryan
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
mstemp Avatar
Barrie,
That pan looks different than many I have seen. Seems to have the deeper section run further forward.
Rimmer Brothers does not seem to carry the SD1 pan but does show this one for the early versions of MGR V8. Looks to have the deepened section closer to the 3rd row of bolts. Also has a different front piece to fit a later timing cover so may not work with your setup.
I assume the FastCars piece has the crossmember part further back which is hitting your pan.
Edited 1 time(s). Last edit at 2017-04-13 10:56 AM by mstemp.
ERR5220.JPG    975 bytes
Jim Blackwood Avatar
Jim Blackwood * BlownMGB-V8
Gunpowder Rd., USA   USA
Just dent it in where it hits.
mgv8glen Avatar
mgv8glen Glenn Towery
Dover, Delaware, USA   USA
Barrie, the oil pan you show in the pic. is the BIG & HEAVY Rover 3.9/4.2 oil pan. I used this pan with my 4.8 Rover 300 Buick engine build up 25 years ago. Built a hand made oil pump pick up tube in the back off the ban & baffles with a one way baffle door & left the plate in the oil pan to help keep the oil in the bottom of the oil pan. The only way I could autocross with this oil pan was to over fill the oil pan with extra oil, would hit the brakes real hard & turn & there was no oil pressure!!!! I went back to the smaller & much lighter Rover 3500/3500S oil pan. The SD1 & TR8 pan all the oil sits in the back 1/3 of the pan. So you can find a MGB V-8 / Rover 3500 oil pan or TR8/SD1 pan or cut up & re weld you Heavy Duty oil pan.
Denis Avatar
Denis Denis Hill
Barrie I have a couple of early sumps, I will take some measurements plus the one in the GT Denis
68 B roadster, Daffodil yellow, Moss supercharger, Burgess SC head, SC cam, Mikuni HSR 48 carburetor and engine built for supercharging.
73 BGT V8 conversion starting with a bare shell. Built the engine early in the year with high comp pistons and a few other nice but not too wild bits. Have completed the firewall and steering mods but it is a complete resto and will take time. I am however really enjoying this new project.
Denis Avatar
Denis Denis Hill
Barrie Just measured 3 sumps (oil pans) one still on a 3500 and another I have here and both are 145mm deep and the deep part is 270mm from the front lip
The one on my GT 3.9 is different at 130mm deep and the deep part is only 200mm from the front lip. Both would work in my setup providing you used the correct oil pickup, though the one on it looks as if it was designed for the job and gives more ground clearance. Denis
If you are short any OE FI bits your welcome to the parts of my engine.
Edited 1 time(s). Last edit at 2017-04-13 07:35 PM by Denis.
Thanks Denis. Essentially I need a sump with a shorter or more shallow deep section. I'll get some measurements off mine.
By inside I meant if there was anything at the thin end on the block itself which might foul if we "modified" the front. While my guru (who's an ace fabricator) can modify it it might be best to get a different shaped sump - if that's possible.
Edited 1 time(s). Last edit at 2017-04-13 08:34 PM by MGB567.
Denis Avatar
Denis Denis Hill
Barrie that sump in your pic looks a lot deeper than anything I have. The one in my car is a 95 model 3.9. Must be close to the last of the 3.9 as it has the later 10 bolt heads and the pads that can be drilled for 4 bolt mains. Looks a lot shallower than yours. If you go shorter and shallower you will cut down the oil capacity. Denis.
"If you go shorter and shallower you will cut down the oil capacity."
Good point. According to the interweb the Chimaera had a dry sump but TRS never mentioned that so I'll have to look and see if there are two oil pumps in there. I've never had reason so far to drop the sump and as I noted TRS just gave me one. I can't find (yet) a capacity other than on the 4 litre version which is reckoned to be around 6.3 litres; it's never easy is it? If allelse fails it'll be a call to TRS who no doubt will try to sell me a dry sump kit.
mgv8glen Avatar
Barrie, I tried to tell you in a polite way that the Rover big oil pan is junk! If you autocross you will lose your oil pressure, I know I did & we did the mods. to the oil pan to help me from loosing my oil pressure when I was autocrossing The oil pan was made for a TANK! think & heavy & holds too much oil that's has too much area to move around in. I bet the big pan is at least 10 lbs. heaver than the one you need. FWIW
I didn't miss your point Glenn. So far I haven't found any of the sumps you mention for sale but I am searching.
Denis I did measure my depth but like a fool I thought I'd remember the figure - I'll have to do it again (and check against your measurements). I've never been "involved" with dry sumps before but I now know I don't have that setup despite the interweb saying that motor was dry sumped. I still need to figure out what oil capacity I need and then try and find one that's suitable. There are a number of options to resolve my current issue; it's just determining the best.
