Aluminum radiator replacement suggestions for 3.4l V6
john73bgt Avatar
john73bgt Silver Member John Chrisler
Loma Linda, California, USA   USA
1973 MG MGB GT V6 Conversion "Serenity"
I'm currently using a '77 MGB radiator to cool my 3.4L V6 and find it lacking when the local air temp is above 80 degrees. When driving in town(stop n go) my engine temp reaches 230 degrees. Looking to replace it with an aluminum radiator, but know nothing about the cooling capabilities. Should I go with a 2 or 3 row or does this really make a difference. Looking for recommendations and ideas.
john73bgt Avatar
Also looking for a good fan and thermostatic controller, too.
260mgb Jim Nichols
Sequim,WA, USA   USA
John, A lot of guys use a 64-66 Mustang radiator. A Volvo fan and controller works good.
http://www.mgexp.com/phorum/read.php?40,3304208
Edited 1 time(s). Last edit at 2017-03-14 10:14 AM by 260mgb.
cstrong45 Avatar
cstrong45 Silver Member Charles Strong
Bainbridge Island, Washington, USA   USA
John I used 66 mustange aluminum rad. I can tell you it did not change the heat characteristics. I am assuming you are using the computer that came with the 3.4. Gm designed that to turn on the fan around 225 give or take some error and turn off at 215 give or take. That is what you will have. I suggest you used a switch to turn on the fan first before investing in an aluminum rad. Just my two centssmoking smiley
Ray Bee Avatar
Ray Bee Ray B
Cobourg, Ontario, Canada   CAN
X2 with Charles statement. I have adjusted my fan to go ON at 215 and OFF at 202 with a 195 T stat installed in my 3.4l . I also have the aluminum rad installed from a 66 mustang Model AE251. Do a search on the internet with AE251 and you get the specs on the rad or PM me and I can give you the details.
BMC Avatar
We are working on a 77-80 direct replacement specifically for the conversions.... I hope to see the first in a month. Aluminium, direct bolt in.
-BMC.
dukesplace Avatar
dukesplace Timothy Ringland
Headingley, Manitoba, Canada   CAN
Here is a comparison of the stock B rad and a 65 Mustang aluminum rad. The Mustang rad is quite a bit larger. I installed an electric 14" as well which turns on at 220 and of at 213 programmed from the ECM.
Even though it looks much bigger it does fit in there well with minor trimming to the rad flange and shimming it forward a bit to clear the sway bar.
I originally went with a Champion Cooling AE251 - which is the 65 Mustang rad. I now have a Champion aluminum rad CC6677 which is a rad for a 66-77 Ford Bronco. This rad has the same dimensions as the 65 Mustang rad but the top inlet is in the center and the bottom outlet is driver side. I found the top center outlet worked really well. The Mustang rad has both outlets driver side.
I had a seam leak on my first one and decided to try the Bronco rad. Full replacement warranty.
Here is the link to the online Champion catalogue.
http://championcooling.com/Catalog%20Online/CHAMPION.CATALOG.htm
Hope this helps.
Tim
DSCN1707.jpg    63.1 KB
DSCN1759.jpg    65.7 KB
Bronco rad.jpg    37.8 KB
MG-Maxx Avatar
MG-Maxx Silver Member Charles Waugh
West Haven, Ct, USA   USA
1979 MG MGB MkIII "Rumpelstiltskin"
2008 Chevrolet HHR
Brian
Here are a couple shots of the room between the stock radiator and the GM 3500. The engine is back against the firewall as much as possible.
I am using the early CW timing cover from the 88 2.8 v6 which has hose on drivers side. The thermostat housing exits straight out under the throttlebody.
Not married to the catch can being on passenger side. Maybe moving it depending on other projects.
Chuck
Hamden, CT
79 MGB - Rumpelstiltskin
Just awakened after a 10 year slumber.
GM 60V6 Gen 3 - 3.5L EFI V6 T-5.
20170328_180350[1].jpg    54.9 KB
20170328_172753.jpg    60.4 KB
British Columbia, Canada   CAN
My Mustang aluminum rad has both outlets on the passenger side. To fit it I have to cancel the flip front end I made, which I do not mind because flip front ends only work when the inner fender is also part of it, which mine was not.
Townsend, Tennessee, USA   USA
Champion CC251 used here. Designed to fit a Falcon/Comet or Mustang with V8 conversion. 1.5" inlet top right, 1.75" outlet bottom left. BIG radiator, but fits nicely and does a great job. http://www.championradiators.com/product/CC251
'73 MGB
'69 MGB GT/V6 Conversion
Victor TF
GT Radiator.jpg    72.4 KB
GT Radiator-2.jpg    79.1 KB
